k so the old headlights were 4 wires each side, and the new ones are 3 each side, what do i do with the one wire not being used? jus tape it and tuck away?
read the sticky about swapping front ends at the top of the exterior forum home page. i think that might shed some light on the subject
or you can just search the topic since its been brought up almost every other day
i have, it tells where to hook the 3 wires up to, but nothing about the not being used
u use all 4 wires.. i did anyway.. and so far i havent had any probs..
Manta Z(The Primered One) wrote:u use all 4 wires.. i did anyway.. and so far i havent had any probs..
Use that method, then turn your car... and put into drive and turn your headlights on. Make sure you engage both highs and lows.. If your DRL light in your cluster starts to flash after a couple mins. You'll have to disable your DRL's for good. This is what happend with my car after i just did the swap to mine for the type J-kit. Remove your dash inside the car and the wire harness going into your gauge cluster, the thin Dark blue wire comming out of pin B8 cut. No more DRL's and working lights with no flashing DRL light.
Also make sure if they worked fine teh first time u tested em out, then u drive for a bit and one goes dim..
first thing to do is check the fuse
@ CRJ
Manta Z(The Primered One) wrote:Also make sure if they worked fine teh first time u tested em out, then u drive for a bit and one goes dim..
@ CRJ
Hey now... sometimes the answer just lyes right in front of our nose...
......... I just wasn't seeing it at first...LMAO!
