Headlight difference - Exterior Forum
Monday, April 24, 2006 5:43 AM
Does anyone know the size difference in the 99 headlights and corners to the 00 headlights and corners? I'm thinking about switching headlights since there is such a huge gap with everything in my front end.
Re: Headlight difference
Monday, April 24, 2006 5:57 AM
About an inch.
Monday, April 24, 2006 12:33 PM
Anyone think I would be able to put in '00 headlights for mine? I have a HUGE gap in my front bumper, fenders and hood and am removing the cf covers because I don't want them anymore. There is an even bigger gap if I do that.
Monday, April 24, 2006 1:02 PM
Was your front bumper cover designed for 95-99? or 2K-2K2? They have a different molding from the top of the bumper to the bottom of the headlights...
Knowledge about everything and yet an expert of nothing!!
Jack of all trades.
Monday, April 24, 2006 1:13 PM
There is a sticky at the top of the page for the headlight swaps by MantaZ
I have a 2001 and did the conversion to mine, he has a 96? and he did a conversion to my 01 front end
MantaZ worked on that for a LONG time that way questions like this could be answered.. it should tell you everything you need to know, mostly youll need a donor wiring harness out of the new car and wire it to your exsisting harness to work right, plus Fenders ( or brackets ) from the other years setup
Good Luck
Monday, April 24, 2006 4:50 PM
Well I did a conversion from an '04 to a '99 already. I have ALOT of wiring issues from my headlights and figured it would be better to just get a decent headlight I could work with then ones that have a gap. My friend has an '01 and the same front bumper, everything fits perfectly on his, mine however doesn't.
Tuesday, April 25, 2006 3:26 AM
doing 00 swap might help. u may still have to take a dremel and shave it under the headlights a lil if u have probs with the 00 headlights sliding in. So that wouldnt be bad. Just make sure u adjust ur headlights right how u need them before u do trimming and what not because that could change the gap also. Do u still have ur old 04 wire pigtails? Because they use the same 9007 headlight bulb as teh 00 cavs do. So then u would have ur wiring solution fixed, and be able to use the 00 headlights. If u dont have those pigtails anymore make sure u go to a junk yard and try to get a set of 03-05 cavs.. u dont NEED to but it would make connecting the wires easier cuz u just have to match up the colors.
Now that i look at my write up i forgot to include 03-05 cavy wire colors.. Ill have to get those and have a mod edit that in for me.
Tuesday, April 25, 2006 5:09 AM
Yeah, I would have to go to a junkyard either way to get a new harness, this just seems simple then messing with the old ones. I guess we'll try it and see where it takes me. I'll let everyone know!
Tuesday, April 25, 2006 7:31 AM
If u need any help with anything, you got my AIM.
