i was just thinking...im about to get a kit..but yet i do all my own work on my car and the ones ive seen so far with kits are so low i dont see how you get the car off the ground...
   like say i wanted to change my oil..how do you guys get  under your cars....i usually use these  ramps to drive up on and just roll under the car....im just curious cus i just dont get it lol
you can get ramps for lowered cars.  try a few local parts stores.  or if you switch to using a jack you can get mini-ramps to raise the car enough to slip a jack under it. pep boys has those.
<img src="http://home.comcast.net/~dslabuda/dsltwist.gif" border="0">
<a href="http://www.modasylum.com">www.modasylum.com</a>
wow...didnt see that one coming lol  thanks
the stupid jack that came with the car, ha ha, then after it's up high enough, put a real jack underneath for the rest of the way
depends for me.  even w/ my car raised all the way up and on 2x4s its still hard to get under so i drop the one side and the other side raises up a bit more than i can get the factory jack under to get it started then i use my floor jack once it clears the side skirts.  too much work though.  takes me about 30 mins just to get the car up
yea most of the people i kno use 2x4s as well.  As anyone used one of those lowprofile racing jacks that the auto stores have? jw cause i was thinkin about buyin one of those but wasnt sure if itd be worth the money.
Jacob wrote:the stupid jack that came with the car, ha ha, then after it's up high enough, put a real jack underneath for the rest of the way
Same here. Factory jack, then a 4 ton once it's high enough. Then, if it's something pressing, I raise that bastid as high as I can and throw 'er on jackstands.
Ya I say go with 2x4's, I went out and bought the ramps for lowered cars and they still were not low enough
<a href="http://www.whiteboy.ca"><img src="http://www.illusioneye.com/wblogo.gif" border="0" target="_blank">
</a>
<a href="http://www.whiteboy.ca/details.asp?ID=189"> TECHNIC LIP - GET YOURS FIRST</a>
