Are the Headlamps for a 2000 cavalier a different size from the ones from the headlamps on a 95-99 cavalier? If so then how would i go about  fitting them? is it a complicated process or not. I really want to put projectors on my car but unfortunatley nobody makes projectors for the 2000 models.
One last thing about the headlights, your lights have a 9007 bulb which is a one bulb system for the high and low beams.  Pre 00 lights have a two bulb system, one bulb for high and one bulb for low beam.  The instructions above will show you how to wire up pre2k lights to the 00 harness. It's really easy too
Convert 00+ headlights to 95-99
You answered every question that i needed. Thanks a lot for your help.
