Is anyone having problems with their lambo doors not closing. I mean, mine close, but there is a small space between the door and the inner weather strip or whatever that is. It is the area right along the top back corner of my door. i've got a 4 door. I installed the driver side by myself so i didn't have anyone to hold the door in place, but the other day when i did the passenger door, i had my friend press against the door and hold it in place but when i put the kit on and he got off the door, i had the same problem. Basically what I'm asking is, did any body ever get their doors to close all the way without a crack ?
i didn't check mine...but i know mine is fine...I've washed the car plenty of times and no water leaks...does your leak now?
They still need adjusted.  here's the trick.  remove your fender, and loosen the bolts to the door.  leave the bolts that connect to your body connected.  have someone push in where it is not fitting snug to the door, and then tighten the bolts.  That should close your gap in.  If not, you can adjust your door striker a little to pull it in more.
Beat it like it owes you money
