Has anyone ever gotten them to run smooth at idle? Even if I had to bump the idle up to ~1200 or so, I'd just like it to be a bit sneaky
I'm sure you could do it. Getting your idle advance to stay at one number would be a big factor, I've made a couple cars sound like they had massive cams by messing up the spark table for idle. And made one car that did have a massive cam (it better have been a massive cam its power peak was a 7400 and stock redline was 12000, sound like it didnt have one by getting the idle just right.
Sponsored by:
Kronos Performance
I have heard it is doable...just not sure how to do it
Basically what you need to do is, log idle, be looking at the spark advance for idle histogram you should see if switching back and forth from 2 or 3 different cells, make all those cells the same value. That will at least make an improvement.
Sponsored by:
Kronos Performance
Thanks Leafy
my car seems to be fine @ 1000rpm idle with them installed
Are they really that lumpy?
1000+ rpm you should be fine from personal experience. only when my motor is at full temp and finally idles 900rpm then does it get the lopey sound.
