General Motors has previewed its latest in fuel-saving technologies for the upcoming 2009 and 2010 model years. As is the case with other manufacturers, GM has chosen to go the most cost effective direct injection (DI) route to up EPA estimated mpg fuel ratings, decrease emission outputs, and maintain sufficient power in its future vehicle lineups. The highlight of GM's DI surge will be a pair of engines -- a 2.4L four-cylinder and 3.0L V-6 -- set to debut at next month's Detroit auto show under the hood of the 2010 Chevrolet Equinox.
GM's expanding lineup of DI powertrains, it's probably best to break down the technology. Direct-injected motors receive their fuel delivery directly into each cylinder where it first evaporates, cooling the hot compressed air-fuel mixture, which makes it less susceptible to knock and therefore more tolerant of a higher compression ratio. In regular port fuel-injected engines, the injection and evaporation happens in the intake runner, well before the mixture enters the combustion chamber. Generally speaking, the process yields less fuel consumption, equivalent power production and reduced emissions versus non-DI motors. It also allows for cleaner cold starts through an easier ignition
In addition to boasting direct injection, both engines utilize variable valve timing on both the intake and exhaust cams to improve performance. The 2.4L four-banger makes 182 hp at 6700 rpm and 174 lb-ft at 4400 rpm and features a high-compression 11.4:1 ratio for optimal power. Dished pistons allow increased combustion efficiency, while application-specific injectors automatically modulate fuel flow. It's based on the existing 2.4-liter, but the block is now sand-cast to improve strength and withstand the higher in-cylinder pressures (the previous engine used a lost-foam casting method). Its bigger 3.0L V-6 brother (255-hp, 214 lb-ft) is based off the current 3.6L direct-injected unit in the Cadillac CTS and incorporates an isolated fuel injector system for quieter operation. Rubber isolators are used with the fuel rail to diminish vibration and noise as well.
GM introduced its first-generation DI system on a small scale in the 2007 Saturn Sky Red Line and Pontiac Solstice GXP. For the 2009 model year, six engines in 18 global market models will have the technology, with that number jumping up to eight engines in 38 models by MY2010. North America alone will have 18 models featuring DI in the same product cycle. Along with the 2010 Chevrolet Equinox, the technology will be employed by the 2010 Cadillac SRX and 2010 Buick LaCrosse sedan, both of which are also bowing in Detroit.
To give you a better idea of how significant the potential fuel savings DI helps to achieve, consider these figures compiled by GM bean counters. The General's 2009 North American lineup will use 700 million fewer gallons of fuel during the lifetime of its vehicles compared with the 2008 group. That number is expected to hit 1.1 billion gallons for 2010. Enter into the equation a price of $2 to $3 dollars per gallon, and you get a good indication of the total pump savings.
>>>For Sale? Clicky!<<<
wooooooooooo , about time
little late , but better late than never
I'm glad to see they are embracing this technology. My solstice gxp gets 30mpg when my foot stays out of it, and the stock fuel system is good for at about 400whp. Some tuners are reporting closer to 40mpg when they reduce the boost pressure and tinker with cam and ignition timing. Amazing!
This should shut some of the greenies up. DI has been around for a while but is just now becoming "affordable".
This from GM...
2.4L DI details
The new 2.4L DI engine delivers an estimated 180 horsepower (134 kW) @ 6700 rpm and 172 lb.-ft. of torque (232 Nm) @4900 rpm. It uses technology based on GM’s other four-cylinder direct injection applications, but with unique features designed for its specific application. This includes an 11.4:1 compression ratio that helps build power, slightly dished pistons that increase combustion efficiency and injectors with an application-specific flow rate.
GM benchmarked the best fuel system and noise attenuation products to provide customers with quiet operation.
3.0L DI details
The new 3.0L DI engine is a variant of GM’s family of high-feature DOHC V-6 engines that also includes GM’s 3.6L DI engine in the Cadillac CTS – an engine named to Ward’s AutoWorld’s 2009 “Ten Best Engines” list for North America, for the second consecutive year.
The 3.0L is rated at an estimated 255 horsepower (187 kW) and 214 lb.-ft. of torque (290 Nm), for an impressive power-to-displacement ratio of 85 hp per liter. (Output will vary by model.) The 3.0L DI features an isolated fuel injector system that reduces the direct injection high-pressure fuel system pulses for quieter operation. Rubber isolators are used with the fuel rail to eliminate metal-to-metal contact that would otherwise transmit noise and vibration from the high-pressure fuel system.
Along with direct injection technology, both the 3.0L DI and 2.4L DI engines use variable valve timing to optimize power and fuel efficiency across the rpm band, as well as reduce emissions.
good stuff for sure hopefully that 2.4 eco takes well to the boost
