i just found out about the cobalt ss turbocharged, and i do believe its the only and last year the cobalt ss are coming out
but here are the specs on it:
2008 CHEVROLET COBALT SS SPECIFICATIONS
Overview
Model:
Cobalt SS
Body style / driveline:
5-passenger sedan and coupe, unitized frame,
front engine, front-wheel drive
Construction:
2-sided galvanized steel on exterior panels (except roof)
EPA vehicle class:
compact car
Manufacturing location:
Lordstown , Ohio
Key competitors:
Honda Civic Si, MazdaSpeed 3, Volkswagen GTI, MINI Cooper S
Engines
Ecotec 2.0L DI Turbo VVT
Application:
std on SS
Type:
2.0L DOHC I-4
Displacement (cu in / cc):
122 / 1998
Bore & stroke (in / mm):
3.39 x 3.39 / 86 x 86
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
DOHC, 4 valves per cylinder; dual continuous variable valve timing
Ignition system:
individual coil-on-plug
Fuel delivery:
direct-injection with a variable high-pressure rail and electronic throttle control
Compression ratio:
9.2:1
Horsepower (hp / kW @ rpm):
260 / 194 @ 5300*
Torque (lb-ft / Nm @ rpm):
260 / 353 @ 2000*
Recommended fuel:
premium recommended but not required
Maximum engine speed (rpm):
6300 rpm
Emissions controls:
close-coupled catalytic converters, Quick-Sync 58x ignition system; returnless fuel rail; wide-range O 2 sensor
Estimated fuel economy:
TBD
Transmission
GM Powertrain Sweden F35 5-speed manual
Gear ratios: (:1):
First:
3.38
Second:
1.76
Third:
1.18
Fourth:
0.89
Fifth:
0.70
Reverse:
3.17
Final drive ratio:
3.82:1
Chassis/Suspension
Front:
MacPherson independent strut-type with direct acting, 24mm solid stabilizer bar
Rear:
semi-independent torsion beam with montoube gas shocks; 24mm solid stabilizer bar
Steering type:
electric, power-assisted variable-speed rack-and-pinion
Steering ratio:
14.8:1 (variable)
Steering wheel turns, lock-to-lock:
TBD
Turning circle, curb-to-curb (ft / m):
39.4 / 12
Brakes
Type:
power 4-wheel disc with standard anti-lock; 38mm Brembo four-piston fixed calipers in front and 40mm single-piston rear calipers
Rotor diameter x thickness (in / mm):
front: 12.4 x 1.02 / 315 x 26 (vented)
Disc diameter x width (in / mm):
rear: 11.5 x 0.79 / 292 x 20 (vented)
Wheels/Tires
Wheel size and type:
18 x 7.5-inch split-spoke polished forged aluminum
Tires:
P225/40ZR18 high-performance
Dimensions
Exterior
Wheelbase (in / mm):
103.5 / 2628
Overall length (in / mm):
180.5 / 4585
Overall width (in / mm):
67.9 / 1725
Overall height (in / mm):
55.7 / 1415.4
Track (in / mm):
front: 58.6 / 1490
rear: 58.1 / 1476
Minimum ground clearance
(in / mm):
TBD
Curb weight (lb / kg):
2975 / 1349
Weight distribution (% front / rear):
60 / 40
Interior
Coupe
Front
Rear
Seating capacity:
2
3
Headroom (in / mm):
38.7 / 984
35.7 / 905.7
Legroom (in / mm):
42 / 1066.5
32.2 / 817.5
Shoulder room (in / mm):
53 / 1346.5
49 / 1245.8
Hip room (in / mm):
49.5 / 1257.1
46.1 / 1171.8
Capacities
EPA passenger volume (cu ft / L):
87 / 243.5
EPA interior volume (cu ft / L):
97 / 2747
Cargo volume (cu ft /L):
13.9 / 394
Trailer towing maximum (lb / kg):
not recommended
Fuel tank (gal / L):
13.2 / 49
Engine oil (qt / L):
5 / 4.7
Cooling system (qt / L):
TBD
errrrrrrrrrrrrrrrrrrrrrrrrr
yeah
old news
The Cobalt SS and the Cobalt Turbo are two different models. The Cobalt SS Supercharged was discontinued for 2008, so 2007 was the last yeat for it. The 4-dr and 2dr "SS" models, were replaced by the Cobalt "Sport". The Cobalt Turbo is what is coming out later in 2008, but it doesn't have the SS badge as far as I know, unless something changed.
.... and they wouldnt dump that kind od money into it, from a s/c to a turbo and discontinue it. sweet ride none the less
