Hey guys,
I was wondering if anyone knew or had pictures of a vacuum line that i can t a boost gauge to for a 2.4l cavalier.
thx
are you running a turbo or supercharger
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
run it off the little nipple on your blowoff valve
what is the BEST place to install one on a ld9 s/c?
jbp built ld9
60mm tb
custom fender well 3"cai without battery removal
all prothane motor mounts and control arm mounts
mp45
pulley boys 2.5 pulley and quick change
aem water meth throug modified ebay spacer
kyb agx dial a rid struts
2" drop sprint springs
need to break it in then a good tune
winter plan :try twin charge if that dont work just turbo
i believe its the fuel pressure reg..
8 psi with m62 and IAT under 100
