I have a few questions.
What wheel do you have (who makes it and whats the name of the wheel)?
Whats the offset?
What did you have to do to make it fit?
What size tire are you running?
What brand is your tire?
Thank....
Just so you know I am asking because a wheel co. is telling me I cant fit 20" wheels on my 2002 cavalier.
dont listen to them.. you can fit them pretty easily. You just need 20x7.5 inch wheels and 225/30/20 tires.
check my profile for my setup.
The only mod you may have to do is roll your fenders if your lowered alot. Thats it.
Will a 20X8.5 fit.
I am lowered about 1.5 -2.0
no 20x8.5 will not fit..i have 20x8 and its about as far as u can possibly go. i am running a 225/30/20 on mine and thats no tire at all. I am lowered also, but didnt have to do any mods to make them fit.
i have MB sparks btw..but if u do a 7.5 or 8 width u should be fine.
I am getting a three peice wheel With a carbon fiber lip (real carbon fiber) in a 20X7.5
What offset should I go with?
please just read around about offsets on here. its getting really old with people asking the same thing. assuming your new ill try to help you as best as possible. typically anything that is 7-8in wide you can work with anything from 38mm to 45mm. depending on the wheel and width you can do other offsets (it also depends on your suspension too). i was running a 7.5 wide wheel with a 48mm offset on air ride and it was fine.
best thing for you to do is list the offsets that the wheels comes in then we can better help you. i would assume it probably comes in a 42 or 45mm offset
AWD GS wrote:best thing for you to do is list the offsets that the wheels comes in then we can better help you. i would assume it probably comes in a 42 or 45mm offset
yeah, just list what they come in, like ^ said, should be 42 or 45..mine are a 45mm offset..if that helps you out, they fit fine.
can you still fit a 35 on 20's? i dont really wanna go any smaller of a tire seeing as i bent one of my 19's already with a 35
www.driftnamiperformance.com
20x7.5 45 offset Custom drilled
Steve-O wrote:can you still fit a 35 on 20's? i dont really wanna go any smaller of a tire seeing as i bent one of my 19's already with a 35
I'm running 35's, but anymore than a 1.5 inch drop and you will be scrubbin and your inner fender will need to be cut, lol.
