Where can I get a rebuild kit for the 04 getrag f23?
Ive looked everywhere almost quite literally, and have not been able to find it, maybe Im not typing the right thing in the google bar or something.
Its something I need to do eventually since my 3rd gear synchro is shot. So maybe if I can just get away with buying new synchros instead of the whole kit, that might be better.
Im not going for extreme high horsepower, probably less than 300, so I dont need a bulletproof tranny, just a simple rebuild.
You will probabally want to replace the shift forks if your synchro is shot. They are known for bending and causing that. You can order the parts through a dealer.
___________________________________________________________________
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
I might have a 3/4 gear set. Used. 3500 miles.
if your rebuilding it yourself cool but if your looking for the rebuild kit and taking it to someone, screw that. grab a yard one for couple hundred.
