Hello everyone, I've done lots of forum searching about aluminum flywheels and i have read the pros and cons of gettting one. I like the idea of getting one, and i am willing put up with the ease of drivability.
but is it worth it? I have a 97 Cavalier 2.2 ohv. I just ordered a new spce stage 1 clutch and if im going to do the clutch i figure if i ever do want to get an aluminum flywheel now is the time.
Are the gains i will see worth the $350 I would spend on the flywheel? I'm in college and dropping this much money into my car has to be well justified.
Just looking for everyones opions, should i do it?
Thanks Jason
"Fight crime, shoot back"
You will see the increase in HP you lost by the old flywheel. It will rev MUCH faster. Fidanza is the way to go on the flywheels. We have that one in stock. Since you are in that area it only takes an extra 15 min to install it. I never regretted putting one on my car.
-Aaron
www.TurboTechRacing.com
Thank you, and i was actually planning on buying the flywheel from you guys. You had the best prices i could find. Any other opinions?
Spec is the only other option, that i know of. Fidanza USE to make the Spec clutches but now Spec makes their own. Spec is about $50 more. I dont know if ACT makes one yet. Last time we checked they didnt.
-Aaron
Once you go light weight, you'll never go back.....
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
SpeedRacerZ wrote:Once you go light weight, you'll never go back.....
Ditto
and that statement goes for alot of things...
What are you doing with the car? The light weight may hurt rather than help you in some cases.
I would say that in most cases you will be more than happy with the few more ponys to the ground and the engine reving up faster will get you in the meat of the power band much faster, which translates into faster track times.
I got a question for those that have the aluminum flywheel, how many tenths did you oick up from the aluminum flywheel in the 1/4 mile??
I have recently installed a spec stage 3 clutch and fidanza flywheel in my car but the slave that came with the kit iwas bad so i had to take it to a trans shop and have then R& R the slave with a new one. Hopefully ill have it back tommorow sometime and next weekend will have some updated track times.
Mike
1992 GMC Sonoma GT #492. Oh, Its just a stock V6!
1999 Cavalier Coupe, daily driver, 2200/M5. Mods and pics are in my registry.
That pretty much says it all.
Support the site that supports your habit, Go Premium.
wow, thank you guys.
I think im going to wait on the clutch install and flywheel till spring but im pretty sure i will get on.
And what i like to do with my car is auto-cross, and some drag racing
thanks for all the input, i love this forum. the ppl on it and there knowledge is awesome
Jason
I hear that with the aluminum fly wheel you'll lose some down low to midrange, but you'll get more top-end. Also an aluminum flywheel will wear out faster because it is aluminum. I got my stocker resurfaced and I dont regret it one bit. Good luck.
____________________________________________________________________
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
Jbody2nr wrote:I hear that with the aluminum fly wheel you'll lose some down low to midrange, but you'll get more top-end. Also an aluminum flywheel will wear out faster because it is aluminum. I got my stocker resurfaced and I dont regret it one bit. Good luck.
The aluminum flywheel will not war out faster, it has a steel insert that the clutch disk wear on, so it will last as long or longer than the stocker, and the steel insert is replacable shuld somthing happen to it.
Mike
HotRodV6 wrote:Jbody2nr wrote:I hear that with the aluminum fly wheel you'll lose some down low to midrange, but you'll get more top-end. Also an aluminum flywheel will wear out faster because it is aluminum. I got my stocker resurfaced and I dont regret it one bit. Good luck.
Agreed in the long run you replace that insert for about $75 and you have a new flywheel again! Dont even have to resurface it.
-Aaron
micromag97 wrote:And what i like to do with my car is auto-cross, and some drag racing
The reason I didn't get a lightweight flywheel is becasue I autocross. Not enough low end power.
yeah, you better be making some nice low end powe (like a superchager would give) if you want the fly wheel to be all around effective.
You learn something new everyday.
I have a Fidanza and i love it but i have a 2.4 so i am not sure if Fidanza has it. May be they do. But Fidanza is a popular flywheel.
all the time
Fidanza has a flywheel for every engine for the 3rd gen cavaliers. 2.2 OHV, 2.4L and the ecotec. They even have them for the cobalt already.
-Aaron
