ive been getting parts to build up my 2200 for more boost and thanks to adlers list of mods ive been trying to copy .so here is what ive got :
1. velinia .30 over bore forged pistons
2. eagle esp rods
3.howell auto pushrods
4. crane gold edition roller rockers
5.new oil pump
6.new water pump
7.new timing parts
8.felpro eng gasket kit
9.cav conn s/s valves
10. ported head shaved .15ths
11.cleviett bearings (main,rod,and cam)
12.msd dis 2
13. safc
14.rc 310cc inj
15. aeromotive afpr (boost dependant)
16.braided fuel lines.
17.cav conn turbo kit t3 garret
18.greddy fmic 2.25 piping
19.trans shift kit some other stuff i cant remember anything im missing ?oh does anybody have a spare block they want to sell?
13's or blowning it. one way or the other!
Well you might not of put it up there, or maybe i missed it, but if you dont have a new fuel pump you sure as hell want to get one. And some MSD coil packs and adapter modules to go with that DIS-2, also to use the Boost retard on the DIS-2 that comes with boost retard (not sure if its the one you have) you have to buy a 2 or 3 bar MSD MAP sensor thing too.
Where did you get your aeromotive afpr, is it direct bolt on?
'99 2200 LS CX1 Sport
Pushrods & Nitrous! wrote:Where did you get your aeromotive afpr, is it direct bolt on?
it should be the same as the 93-96 LT1 F-body and 96-99 LT1 Corvette.
aeromotives are universal (at least some of them are) so a bit of modifying to the fuel rail would be required.
IMO, aeromotive's are the best afpr to go with.
those afpr are pricey, don't you think the injectors might be a little small?
saturn 5speed turbo 8psi
93' z24 grand prix turbo 3.1 swap, crane 272 cam, 3100 hybrid op end swap, t04b turbo
well the adfpr you can get at summit racing for 136.00 and they are universal so you have to modify your fuel rail. and the 310cc inj should be good up to about 15lbs of boost but yes i will need bigger ones probably 440cc .
Aeromotive may be slightly pricey... however they are by far the best fuel system manufacturer ever.
