but at
87mph
spun on and off until 70mph or so (yes i said 70! bumpy track) with @!#$ty nankang 225/40/
18.
.8bar of boost, 82 degrees 80% humidity, spinning way paste the 2.24 60'... do the math
________________________________________________
...bone stock
thats awsome man good job on the 87 mph. what was next to you to run a 7.6
View my MySpace
Awesome!!
What kind of boost #'s are you running?
thanks guys. as for boost .8 bar which is roughly 12psi. next to me was a spraying 5.0 foxbody with some heavy slicks!
...bone stock
Geekd,
It looks like you need a set of slicks.
When you have slicks, it will be time for a set of stronger axles. I am selling my set of DriveShaftShop level 3 axles & hubs with ARP wheel studs.
275hp & 306tq - 1999 2.2 ohv
13.2 @ 108 mph
actually i blew a couple of dss axles already and the stock izusu tranny is still holding up (holding my breath... it wont take much more) as soon as i can track down a good condition quad 4 ho 5-speed tranny and swap that in, slicks will be a must
...bone stock
Sleeping on the tree? Lol jk man i really do love your car. Traction is a bitch, i wish my car was too powerfull to get traction haha. Good slip bro.
<a href="http://www.cardomain.com/ride/448390"><img src="http://www.clubcav.com/gallery/albums/userpics/10271/sig7.5.jpg">
dave thats bad as ss man. I pulled a 9.009 at I think 76 and that was with a 2.0 60ft time. If you get good traction I know you would dip into the low 13s high 12s even on a few more pounds man. Your motor can take alot with it being fully built . Up it to 15 and you would be pulling some awesome times.
<img src="http://img.photobucket.com/albums/v292/dragmyz24/shoppedcav2.jpg">
01 Z24 Turbo with a snail shaped power improver.
Which DSS axles were you using? The level 2s or the level 3s with the hubs?
13.2 @ 108 mph
adler, i have the level 2's without hubs.
i blew the drivers side axle twice, specifically the outter cv joint locked up TWICE! gahh. now on a stock drivers side, with a broken dss level 2, that isnt warrantied anymore apparently.
...bone stock
Well, its time for you to upgrade. Buy my level 3s with the hubs.
13.2 @ 108 mph
If you're spinning your tires at 70mph you need to get a multi stage boost controller to be able to run a lower boost pressure at lower speeds.
What was the 1/4 ET and mph, or was this just a 1/8 mile track?
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
get some traction and do a 1/4 pass. also adler arent your axles beefer than stage 3?
i'm not worried much about the axles... not yet anyway. i'm working on that HO tranny/axle swap that sunfightergt and a couple others have done.
and yes this was just an 1/8th mile track, and boy was it bumpy and slippery. boost wasn't my problem. the 18" wheels with those tires and a soft suspension is killing me. maybe if i was motivated i'll have it well into the 12's by next season.
btw if this were a good track on some smaller wheels and drag radials.... with that speed i should be already in the 12's... but may be missing my transmission after that run
...bone stock
Boosted2point4 wrote:get some traction and do a 1/4 pass. also adler arent your axles beefer than stage 3?
Yea, I forgot about that. The shafts were upgraded to a 300rr metal and hubs have been heat treated. So my axles & hubs are actually stronger than the level 3s.
13.2 @ 108 mph
