So its looking like I'm going to get a SICK deal on a CobaltSS G85 and trading in the Cavy. I want to remove the GM supercharger, kit 330cc injectors, Gen II map sensor ect..., but I don't know how it will run without those parts being that it has the GM reflash?? Anyone tried it yet? If I can do it most of the kit will be up for sale CHEAP!
Modds:
GM Stage 2 with SFPHQ 2.8 pulley
Injen Intake
GM Dual Pass Aftercooler w15psi Surge Tank
GMPP Exhaust Manifold
CTi 3" Downpipe and Cat
Custom 3" Cat Back with Dynomax Super Turbo Muffler
ZZ Engine Mount
ZZ Front Trans Mount
B&M Shifter
NGK BKR7E Plugs
DC Strut Tower Brace
Soon to be installed:
2.6 pulley, Siemens 60lbs Injectors, NGK 2 Step Colder Plugs
Tune Time Custom Dyno Tune
i heard somewhere they charged a guy 80 bucks to reflash his car with the program, not sure what they would charge to do a stock reflash.
btw, how cheap
YUP they charged me $80 at my dealer for the reflash when I installed the kit. Scumbags were all pissed off cause I had to instruct them on what and how to do it. I just dont want to waste 2-3 hours returning it back to semi stock then come to find out that it wont work. I would imagine if it did I would run very rich.
Modds:
Injen Intake
ZZ Engine Mount
B&M Shifter
NGK BKR7E Plugs
im sure they'll do the same again then. but i think u could def sell the s/c on here and gain some pocket cash, even if it cost u 80 bucks.
i thought there was someone on here who tried and it wouldnt work. That they couldnt reflash it back to normal. I doubt they even have a reflash to turn it back to normal. I mean do you really think a dealer would need that? THats something that like a whole 5 people would need. Also the same guy said the car didnt run right with the reflash and no charger. If i were you, i would try and sell the ECU+a trade for a stock 00-02 ECU. Im sure theres some guy with a turbo who would like it. Just gotta write down the milage first.
13.91@102.77
you should be able to run it without problems, but you would have to leave the 2bar map in it. it you put the stock map back in it will def not run right.
Don't steal, the government doesn't like competition
if you take all that of the car wont run right , the map sensor values will be different , and will cause problems
also the s/c program is set for the larger injectors , and that will cause it to run messed up also
you will need to have it reflashed back to stock
Yea your most likely rite. Ok then anyone want to just buy the whole car? LoL
Modds:
Injen Intake
ZZ Engine Mount
B&M Shifter
NGK BKR7E Plugs
take everything but the 2bar map off, drive it nicely to the dealer get it flashed back to stock, put stock map back on and it will be normal again. it might not run the best until you get it reflashed but it will run, just be easy on it.
or trade someone on here for a stock computer plus cash, there are lots of people looking for flashed computers....
I had mine reflashed back to stock, they had to call to get the stock 2.4l reflash info, but it was done.
Price? Depends on who you talk to. To have it reflashed I paid $85, to have it reflashed back to stock, the guy was awesome and only charged $50.
tell you what, cut me a deal on the s/c, and I'll send you a stock flashed PCM....... and any stock parts you need for your cav.....
You can drive it on just the stock MAP, and injectors...... with the reflash....... runs just fine. (just ask Smokey..... since he drove all the way home with it....
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Thought about posting that, but didn't want a poo-fest from it.
Drove 200 some miles back home with the reflash, stock injectors, stock MAP even, and ran fine. Was a lot richer, but nothing my SAFC couldn't handle
Why it works? Hell if I know, I kept bugging Brian about it not being the actual reflash. But it sure is, just found out tonight
O noes!
tell us more about the cobalt SS deal you got.
