Well I am going to make a trip to the junkyard this week to look for some stuff for the turbo project. I am going to buy new IC turbo and I already have the MANI. any suggestions? (I.E. new injectors)
Kick azz is my boost hero!!!
spell heaven right.
good luck bro its a gold mine
LE61T PTE6262 Powered
whoops. Anyone with suggestions.
red tops will be your freind ive had great luck with them i dunno what car they came off of so... i bought mine new, grab a few oil filler/dipsticks i ruined two b4 i got mine right as for any thing else ummm oh the little 90 degree elbow for the water pump bypass i broke mine dont ask
"dude, thats a girls car"
PSHHHTTT NOT ANY MORE!!!!!!!
i've got an eclipse GSX sidemount intercooler unless you are looking for a front mount. send me a message or hit me up on AIM.
Hmmmm I guess you mean incase thats how I rought the oil but Ive got an eco so its all block and pan for me. also does anyone know wheree to get a set of red tops. and whats the elbow water pump bypass look like
just out of curiousity how much bigger are the ford red tops then the RC320cc or the GM SC injectors?
208whp 239wtq
13.7 @ 102mph 2.19 60'
where could I find the red tops?
i just posted a link above where you can get some red tops and the price...
Can i exchange the injectors in my Eco 2.2L (L61) for something bigger? What about taking the injectors from the Eco 2L SC or 2.4 plants? Would this cause problems with the ECU? I am hoping to SC so the extra fuel bandwidth be welcome, correct?
Anybody know what direction I should take, do I need EI's+C or can I just increase flow by swapping out the standard Injectors?
-Steve
Power Curve
it depends on what type of fuel rail you have...if its like the 02 ecotec or the 03+ ecotecs?? would have to see pictures of your set up to see what kind of injectors you can upgrade too. They might even used a whole different style on your speedster ???? if its the 03+ style then you have alot of choices =)
I am pretty sure the the ford red tops would work there something like 220cc's and they fight perfect not sure about the 02 but Im preety sure there the same as my 04.
ford red tops are 30lb injectors..320ccs around..not 220...
whoops my fault. but the fiting is ok right.
fitting is perfect , actually they're 310cc's, forgot you had an ecotec so dont worry bout the oil filler , get your clips from the junkyard too , just solder them in , usually they'll let you have them, the hell with paying 20$ for something i can get for free
yeah but its worth it IMO..becuase these clips harness they sent me are brand new..you actually got to build them..there not clips cut and splice into the wires...you actually got to put the cut end wire on your original harness into the new plug and solder them to the metal little retainer clip ...on both + and - ...then push the retainer clips in the actuall plug. So they look factory and you see no electricle tape outside over a solder wire or whatever. For the free shipping the extra $20.00 you spend on new clips is worth it =)
