I was just wondering weather anyone knows if, lets say Cobalt SS camshafts and the N/A Eco in a Cavi has the same specs?? Lift, duration etc.....
Or a Redline? Could we be able to use them on our Turbo Ecos.
Because if thir cams ARE different they are designed for FI and I am snatching some right away.
11 second daily driver!!!!
Race Related 727-561-9440
13's
----12's
----11's
----10's
i don't see why GM would use the same cam specs. you're probably better off buying an aftermarket FI cam for the ecotec.
Where?? and weather I am running a Turbo or Supercharger if the cams ARE different they would help either or motor, by eliminating overlap and such things.
I don't think the specs are the same either, but I need someone to be sure of this and compare the 2. The N/A and the Super. cams.
13's
----12's
----11's
----10's
the cams in the SS/redline are saabs , and wont work in the 2.2 head
the will only work in the saab sand cast head
Cams for a supercharged or n/a motor will be very similar. Overlap will have a a much different affect on a turbo motor then it would on a n/a or supercharged motor.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
