was wondering what else i had to get for it and how to go about routing it thru the engine bay, its going on my 99 z24 with the 2.4 twin cam ld9
i know i need a turbo manifold, and an intercooler, just not sure what else i need. came with blow off valve, t3t4 turbo, waste gate, and some piping and a spring? not sure what its for.... what else do i need?. thank you!oh and in case you were wondering i traded my xbox 360 for all this....
1999 2.4L w/ nitrous
The spring is most likely an extra wastegate spring with a different stiffness.
Apart from the manifold, you still need oil feed/return lines, vacuum/boost signal hoses, boost controller, larger injectors, downpipe/exhaust and some way to tune.
I have no signiture
is the downpipe just the exhaust? (dont mean to sound stupid)
suggestions on injector size?
and thoughts on tuning whats the best way to go about it?
z24cavi55z24 wrote:suggestions on injector size?
How much boost do you plan on running? what HP do you plan on attaining?
z24cavi55z24 wrote:thoughts on tuning whats the best way to go about it?
HP Tuners....Megasquirt....External FMU.....any one of these....
For a basic turbo you also have to look into:
- fuel pumps (inline, or a new intank) if you want to run a decent amount of boost. The stock pump will only support so much.
- Gauges (I'd suggest a Wideband o2, and Boost Gauge at a MINIMUM)
- Oil feed (to turbo from block) line
- Oil return (to pan from turbo) line
If you want to add an intercooler you have to look into:
- an Intercooler
- Charge pipes
- Couplers
- T-bolt clamps, or worm clamps
- removal of your air intake system and possibly T.B. modifications and whatnot....
- Air filter
If you want to go the cheaper route and use an External FMU, you will need it, as well as the fuel lines and connectors to hook it between the fuel rail and existing fuel line.
I'm sure there are other things, like wire, assorted brass fittings, nuts and bolts, sealant, blah, blah....but this is a start.
It will take some planning, but check the stickys for extra info and make sure that you get the correct manifold for your turbo flange style. It would suck to buy the wrong one...
well from the looks of it im gunna have to do some work lol
what do u suggest for a fuel pump?
I suggest you read the FAQ's, stickies and actually do some research before you throw that on. If you dont even know what a downpipe is then ya got a problem...
"You can only feed them semen for so long before their legs fall off."
Senorguitar19 wrote:I suggest you read the FAQ's, stickies and actually do some research before you throw that on. If you dont even know what a downpipe is then ya got a problem...
well sorry for just making sure and being new to everything. SORRY
z24cavi55z24 wrote:Senorguitar19 wrote:I suggest you read the FAQ's, stickies and actually do some research before you throw that on. If you dont even know what a downpipe is then ya got a problem...
well making sure would be doing the research before hand or even after without posting
my carDomain updated 10/31/09 Forged and Supercharged
why because i wanted to make sure i had an idea of what i need for the cavi from other guys before i actually looked more into it?
I am going to list a bunch of stuff... some of this stuff you may not need depending on your hp goals, but you will get there more easily/safe/legally with most of the listed mods
Turbo/Exhaust
turbo manifold
downpipe (preferably 3")
dump pipe
proper wastegate spring or boost controller
Larger exhaust, cat, and a resonator if you want one (preferably 3") (optional, but recommended)
oil lines and fittings for turbo
Drivetrain
Clutch (optional, but recommended) (You need a clutch that can handle your new power)
LSD (optional, but recommended) (Need to be able to put the power to the ground)
Intake System
air filter
charge pipes
intercooler
blow off vavle
couplers
t-bolts
Vacuum block (Optional)
vacuum tubing
Engine
tapped oil pan
Rods(capable of handling desired hp numbers)
Pistons preferably ~9.0:1 Compression
valvetrain (capable of handling desired hp numbers)
Catchcan (optional, but recommended)
Electronics/Gauges
wideband (optional, but recommended)
boost gauge (optional, but recommended)
gauge pod (optional, but recommended)
Tuning Program or Someone who can dyno tune your car for you
Fuel System
Walbro 255lph fuel pump (optional, but recommended)
Larger injectors according to hp numbers (optional, but recommended)
Other
**Anything in the other category is required in excessive amounts
Time
Money
Research
Patience
That's all I can think of right now
Good Luck!!!
Fill us in!
woops
I made my underling backwards
lol
thanks. that gives me more of an idea, i've been patient with the car so far so whats another 5 months lol
lol... F.U. man... I have a honda
Everyone @!#$s on honda, but that's okay I think they're great.
If you piece together your own kit and have to do everything else (tranny, engine, etc) it can take really long. Trust me, been there, doing that. It might be a little harder for you to source parts than for me because I know there are much more parts readily available in the Honda world than for you, but good luck.
So if your time frame is 5 months you better have deep pockets.
Let us know how it turns out.
Just make sure you take your time and dont rush anything. If you look around good enough you will find good stuff cheap weather its used or new. I pieced together my whole kit for about 1,200-1,300 and most of my stuff is brand new and not knock off stuff. Good luck!!
z24cavi55z24 wrote:why because i wanted to make sure i had an idea of what i need for the cavi from other guys before i actually looked more into it?
Should have done that before getting that stuff. Once you actually know what you are doing you will probably replace what you just got.
219whp - I <3 whine
Tinkles wrote:z24cavi55z24 wrote:why because i wanted to make sure i had an idea of what i need for the cavi from other guys before i actually looked more into it?
I second that.. I wish you the best!
i got it all for cheap so who cares right?
just take your time and do it right.dont let the little trolls on her piss you off,if you have a ?,just ask.someone with smarts will answer
z24cavi55z24 wrote:was wondering what else i had to get for it and how to go about routing it thru the engine bay, its going on my 99 z24 with the 2.4 twin cam ld9
Spring? Idk... That looks like a Tial F38 wastegate, and that spring definately does not belong there. I run a .5BAR spring in my Tial F38 and the one you have there is far too long, has far too many coils, and the coils themselves are far too thin. Who knows what kind of minimum boost you'd make with that spring even if you got it to somehow fit inside the wastegate. My suggestion on the spring, get on ebay and search for "Tial Small Yellow" (Fits the V44 & F38, costs like $32 including shipping), it's the same spring I run, allowing you to run a minimum of like 3.86psi to keep it a safe daily driver. No worries, with a boost controller you can always turn up the boost, the spring only regulates how low the boost will go. Shoot me a PM if you have any further questions, as I myself was in your shoes at one point piecing my kit together.
"Vroom."
"Yo I wouldn't race him, there's not even an interior in his car man."
"Vrooooooom PSSSSHHH!"
"Oh sh*t. F*ck that, dude..."
