Any before anyone asks, supporting mods would be:
Ecotec of course....
Big injectors - 60lbers at least
Upgraded Fuel Pump
Built Bottom End - Rods and Pistons
Clutch
M62 supercharger kit - you need the belt assembly and the intake manifold
Meth injection and dual pass setup would yield the best results
Colder plugs
Hi-performance tires
If this was only next year and just for the blower.....
Here is just alittle something to wet the lips. Estimated TVS pulley sizes and boost pressures.
64mm / 2.5" ~ 27.5 psi
70mm / 2.75" ~ 25 psi
75mm / 2.95" ~ 22.5 psi
80mm / 3.15" ~ 20 psi
85mm / 3.35" ~ 17.5 psi
89mm / 3.5" ~15psi
FYI - The TVS has less heatsoak, more CFM, and more PSI than the M62.
Admiral Jedi wrote:Any before anyone asks, supporting mods would be:
Big injectors - 60lbers at least(Required)
Upgraded Fuel Pump(Required)
Built Bottom End - Rods and Pistons(Required)
Clutch(Eh.....)
M62 supercharger kit - you need the belt assembly and the intake manifold(Required)
Meth injection and dual pass setup would yield the best results(Good things to have anyway)
Colder plugs(Good idea)
Hi-performance tires(Traction is overrated)
Fixed it for you.
Edited 1 time(s). Last edited Monday, February 02, 2009 11:33 AM
Tinkles
v. intr.
1. To make light metallic sounds, as those of a small bell.
2. Informal To urinate.
v. tr.
1. To cause to tinkle.
2. To signal or call by tinkling.
n.
1. A light, clear metallic sound or a sound suggestive of it.
2. An act or instance of tinkling.
I guess the meth injection and dual pass depend on the boost pressure you're gonna be running. Anything smaller than a 3" pulley, I would do too.
oh damn. tax return! not so much.
____________________________________________________________________________
my carDomain updated 8/2/08 Forged B-day!
I really wish they would have gone with something bigger than the 1.3L TVS blower. The 1.6 would have been a better choice.
I'm curious what the difference in power would actually be on my car. I can't say the M62 is even maxed out yet but will be this next season. Maybe if someone were selling a used one for less money, I just can't justify the cost of that blower.
I've yet to see anyone with a cobalt make great use of the TVS yet. Does anyone else have any information on cars that maxed that blower out beyond what the m62 is actually capable of?
If you arent gonna go to the track very often, Meth is way overrated, I have never heard anyone say it does any different.
I see it this way, If you have meth, and you go to the track alot or run your car hard alot, youre gonna be spending a ton on meth, and if your car doesnt see very much track time or slow DD'ing, then its a waste of money to buy the kit.
So you have to decide how you are gonna drive the car before buying meth.
Airtonics, the only person who I know that knows what they are doing with cobalts and tvs is area47, granted he is only running a 3.1 pulley, but he is making around 350 with just valvetrain work downpipe, and a tune.
He actually started a thread about how pissed he is at people who have tvs and arent over 300whp.
it's funny, the want list is close to 30 already, but when time comes to pony up for the cash, i bet about 10 actually get it.
^ Maybe 10. haha $2,000 is a lot of money for a blower.
There are secret upgrades that aren't really spoken of on CSS.net about new generation rotors going into our generation M62 making it capable of flowing enough air for 300whp. But, I read somewhere that was a super aggressive tune. So I dunno.
I wish people would learn how to drive well to go fast instead of going for a ton of power they can't control.
They cobalt ss i got my M62 off was making 284whp and there was still room for a decent amount of upgrades.
Tinkles
v. intr.
v. tr.
n.
Area also has a built head and revs to 1000rpm higher than the rest of us, I'm prob sitting right around 310whp right now, at the bash though the tune was still far from done and heat still affects this blower just as much if not moreso than the M62. Heatsoak is still very much an issue especially when its above 80 out
you guys don't have phenolic spacers?
with a L2A intercooler, methanol injection and phenolic spacers you're still getting heatsoak?
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
ion C2 wrote:you guys don't have phenolic spacers?
no phenolic spacers.
there's the problem, cut one out
650 whp / 543 ft-lb
@turboalero
[ion wrote: C2]there's the problem, cut one out
It is the biggest problem I have seen with the cobalts setup. I am surprised they have not done that sooner.
phenolic spacers wtf is that
It stops heat from transfering from the S/C to the intake mani.
Tinkles
v. intr.
v. tr.
n.
no the primary function of one is to stops heat from transferring from the cylinder head to the intake manifold. if you buy one to use in conjunction with the supercharger to manifold gasket that is what that one would do. the most important one is the "intake manifold->head" spacer.
650 whp / 543 ft-lb
@turboalero
Same idea, i just screwed up on the location. Reduces heat transfer.
Tinkles
v. intr.
v. tr.
n.
Who said the tvs put out more heat that the m62? Harrop said they twisted the rotors 160 degrees to reduce heat while producing more power.
So that means if the tvs is creating the same amount of heat as the m62, the tvs is also gonna be creating more power.
ON THE LSJ, you can make 320hp without porting or having a dualpass(meth or H/E)
While at comparable boost levels the TVS may be less heat that doesn't mean that its not too much already. Sure running stage 2 on a M62 gets you 15-16psi and around 130-140 WOT. Running a TVS at the same level you might only get 120s. But the thing is nobody runs less than 20lbs on a TVS and at that boost level your right back where you started as far as temperature goes and the more you rev it the hotter temps you will get.
While you might be able to make 320 without having a Heat exchanger or dual pass I can promise you that the motor won't live very long.
Edited 1 time(s). Last edited Tuesday, February 03, 2009 3:24 PM
So this upgraded blower is really for the hardcore supercharger guys. I mean the guys who just straight love superchargers regardless of the price and power output.
It sounds like your going to end up spending a lot for a reliable and fast setup, while there are hahn turbo kits out there that will rape you for about the same money.
oldskool wrote:So this upgraded blower is really for the hardcore supercharger guys. I mean the guys who just straight love superchargers regardless of the price and power output.
Yeah, Basically. Some of us like the overall ease of having a supercharger, but not all of like throwing money away.
I guess for some of the Cobalt guys warranty comes into play, it's easy to swap a blower, but not so easy to remove a turbo, put the exhaust back on, then reinstall the blower.
TVS effeciency is in the range of MOST turbo's ~70%+.
The heat is obviously from the boost levels, the intake manifold and head don't flow nearly enough air to keep heat levels down, remember pressurized air heats up..Flow better, less temps, less psi, but MORE power.
the TVS pumps out .32L more than the m62 PER rotation. That is a lot of air.
Also the HAHN set-up is nearly double the cost IIRC, and there is a lot more hidden fee's with it. and will take a weekend to install.. tvs is about 6 bolts total.
