We need dyno numbers!!!!!!!!!
That is a very nice setup!!! Nice work!!
Hoping to have it on the dyno next weekend.
nice set up.
isnt he pressurizing the air to oil seperator? As i see he has that coupler part hooked up that came with the gm s/c kit. i thought i read about some issues some guys were having doing that.
keep us updated.
under the hood looks nice, headlights (or bulbs) are horrible
the wastegate reminds me of one the little air compressors for air air ride setup LOL
sucks he had to turn the boost down but tuning is everything and if you aint got enough fuel to support that 15psi then yeah, you did the right thing in advising him to go down.
Are you scared of the changes coming? The answer is on the inside.
Jake wrote:nice set up.
keep us updated.
You know you bring up a good point and something I have not looked into alot on his set-up. We are not seeing any bad affects so far.
The headlights are HID's.
z yaaaa wrote:the wastegate reminds me of one the little air compressors for air air ride setup LOL
Well he has not turned the boost down yet. The Wastegate spring is a 10psi and the charger puts out 5-6, so that is the 15. The duty cycle only gets high once you get over 105mph. We saw 143mph today. It is holding a nice safe AFR. He will have the boost down soon, but he is taking it easy on it as well.
ah.. built bottom end or stock?
z yaaaa wrote:ah.. built bottom end or stock?
This is a 100% stock LD9. Only mods are charger and boost. Even on a stock clutch.
jeez people freaked on me when i wanted to run my m62 on stock bottom end
8 psi with m62 and IAT under 100
Cody Star wrote:jeez people freaked on me when i wanted to run my m62 on stock bottom end
I got the same reaction when I said I was running 10:1 with the M45, then it became the "recomended" setup.
I like the turbo placement.
Bolt on's
LD9 FTW!
Chris
'02 Z-24 Supercharged
we need dyno numbers asap lol
John Higgins wrote:Jake wrote:isnt he pressurizing the air to oil seperator?
Yep, hook up a longer vacuum hose somewhere pre-turbo.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
and he is missing a bolt on the s/c bracket that is right by the t/b. if,.,.. you want to get picky. hahah
keep us updated and good luck. nice set up for sure.
Jake wrote:and he is missing a bolt on the s/c bracket that is right by the t/b. if,.,.. you want to get picky. hahah
Yes we pointed that out to him.
Jack anytime let me know.
Interesting.
WOAH! im new to this turbo thing but can you really have your turbo set up on the side like that? i've only seen them behind the motor. or is this ok to do cause of the super charger?
frikken sunfire wrote:WOAH! im new to this turbo thing but can you really have your turbo set up on the side like that? i've only seen them behind the motor. or is this ok to do cause of the super charger?
He couldnt fit the turbo behind the engine. And you can mount the turbo anywhere you want, just some locations are more efficient.
^^^ yep and when he says ANYWHERE you want.. he means it. one person has even done a custom remote-mount setup, which locates the turbo clear at the BACK of the car where the stock muffler goes.
Hoping to have the car on the syno tomorrow. Sad part is the owner is swapping to a Ecotec. Will probably be done in a next few weeks.
