i finished it all. pretty fast, a little hard to contol. lol. still need to have it retuned by John Higgins. spins through all of 1st, 2nd, 3rd, & half of 4th gear before i catches traction. but i also just lost 3rd gear and snapped an axle on 2 different nights. sucks. even with the supercharger cranking out 6 psi the turbo is so freakin big, it doesn't spool up until about 3000-3500 RPMs. even in 5th gear the torque steer is bad when it spools. total boost going into the engine is anywhere from12-15psi. 130MPH with now problem at half throttle. with just the supercharger it would have to be a WOT in order to make it to that speed. time to rebuild my trans, replace some axles, lightweight flywheel, spec stage 3 clutch, ultra lightweight crankpulley, & some other bolt ons to free up some more power. as soon as i get all of my stats, vehicle weight, times, & power output. itll be posted!!! thanks to all of the guys who helped out with the info for the build!!
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=86491834&albumID=2118403&imageID=38741188
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=86491834&albumID=2118403&imageID=37133609
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=86491834&albumID=2118403&imageID=38659567
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=86491834&albumID=2118403&imageID=38659533
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=86491834&albumID=2118403&imageID=38659594
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=86491834&albumID=1764016&imageID=39056890
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=86491834&albumID=1764016&imageID=39056941
http://viewmorepics.myspace.com/index.cfm?fuseaction=viewImage&friendID=86491834&albumID=1764016&imageID=36913194
Enjoy life while you can, because you only have one shot. So go BIG or go home.
This car is stupid sick, custom manifold I assume? Love the positioning like that ever since I seen the quad pictured in the Maximum Boost book.
Where did this come from. Jesus.
VID!
Chris
'02 Z-24 Supercharged
I was wondering if you were on here when i saw your cardomain the other day.
psh, slow.
LOL. I agree, VIDS! Im impressed.
Joe Schulte wrote:This car is stupid sick, custom manifold I assume? Love the positioning like that ever since I seen the quad pictured in the Maximum Boost book.
i had a little design help with the manifold routing. but built everything myself. thanks man. just need to find out the figures
Holllllllllllllllly sh!t, this makes owning a j-body not so embarrassing to tell friends
Holly big ass remote mount turbo batman!
You are running the 2.5" pulley still right?
VIDS OR BAN
Edited 2 time(s). Last edited Sunday, November 23, 2008 10:55 AM
Start producing this turbo setup!!!! And make it fit the auto
Badass man. Twincharged, bagged, and a vert. Love it.
Matt Gorman(ECOjunkk) wrote:http://www.j-body.org/forums/read.php?f=40&i=157331&t=157331
wtf
What exactly are you WTF ing??
John Higgins wrote:Matt Gorman(ECOjunkk) wrote:http://www.j-body.org/forums/read.php?f=40&i=157331&t=157331
wtf
My guess would be that he asked recently about doing it and now he is surprised to see it done.
Could be the XS Power turbo too
Joe Schulte wrote:Could be the XS Power turbo too
what do u mean by that?
Ben Wootson wrote:Joe Schulte wrote:Could be the XS Power turbo too
XSPower = you need a new turbo soon.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
My friend is sponsored by XS Power and he put down very good power with no issues with the kit or the turbo for that matter
http://maxhellstern.com if you would like to see his setup
Ben Wootson wrote:time to rebuild my trans, replace some axles, lightweight flywheel, spec stage 3 clutch, ultra lightweight crankpulley, & some other bolt ons to free up some more power.
If you really want to free up power you should take the intake heater off, it would help you out a lot more if you left it in the garage.
And for the record XS Power sucks!
anywhere from 12-15 PSI?
Whats the output of the t/c?
How are you controlling the total boost?
Is your engine built?
well hello from the dark sir!!!!
damn, why is it the quiet ones who hardly ever post have some of the sickest setups?
definitely want to see more of this...
You look so much cuter with something in your mouth.
Joshua Dearman wrote:Ben Wootson wrote:time to rebuild my trans, replace some axles, lightweight flywheel, spec stage 3 clutch, ultra lightweight crankpulley, & some other bolt ons to free up some more power.
just as a heads up to you. im not building it for max power. i want a combination of both bottom and top end. i love this setup and no problems with the XS. i wanted the power from a turbo and still have the ability to auto-X.
z yaaaa wrote:well hello from the dark sir!!!!
thanks, definitly going to keep everything posted as i find out the info
Nick LaManna wrote:anywhere from 12-15 PSI?
i dont know the output of the turbo. need 2 boost gauges to monitor the t/c and total boost in the engine. the waste gate and boost gauge are hooked up to the factory port on the s/c for the fuel pressure reg. i have a 4 way vacuum line fitting for the branch off. the engine isnt built yet . thats why im not trying to run over 12 psi.
If you have problems getting traction going straight.... how the @!#$ are you going to autoX?
Drag it!
Chris
i think your biggest problem is trying to keep it under 12psi. I don't think you should run more than a maximum of 10. I'm pretty sure higher than this isn't good or the motor, and you'll risk blowing it up, but someone correct me if I am wrong.
03 Sunfire - Sold.
Your wrong
Chris
