ran into a problem. email my uncle who works at chevy dealership to see if he can find the parts i'm missing. i bought this from a guy on jbo who then sold it to a guy on jbo/ecotec and then i bought it from him. things may have gotten lost in translation but i'm missin the followin items and they can't be found on gmpd nor at the parts desk. i may even have the wrong part #. any help would be greatly appreciated. my uncle did say i should contact who ever puts together the kits (magnuson for example) to see if they have any parts for it. i called magnuson, they do not make this kit. so any insight on how puts together the kits would be great as well.
any one know who makes the s/c kit as in put its together for crateenginedepot, gmpd, and paceperformance?
these are the parts in the ecotec 2.2 cavalier supercharger kit i'm missing. thanks for your help.
Qty Part # Description
2 12590822 Int Man Stud
5 12590821 Int Man Stud
1 11516506 Int Man Brkt Bolt
5 11518062 Int Bolt
1 11516757 Rad Hse Spt Bolt
1 11589299 Oil Lvl Bolt
1 11518048 Drive Blt Bolt
7 11518532 Int Man / Head Nut
2 12593677 17mm Washer
1 12594613 Rad Hse Suprt Brkt
1 12581198 PCV Connector
1 12110293 Map Connector
1 12052641 IAT Connector
2 12593906 Sensor Plug
1 12052634 Lock Connector
2 11507067 Rad Hose Nut
1 12593905 Throttle Bdy Gskt
1 12593902 Int Man Template
1 10358940 Brk Bstr Hose
1 12590818 Map Sensor Wires
and this is on national backorder
1 12584337 Fuel Pres. Hose
Edited 1 time(s). Last edited Saturday, February 23, 2008 5:34 PM
my carDomain updated 11/5/07 I've got premium. Yes I do. I've got premium. How 'bout you?
Sorry to say dude but you shoulda just bought a complete kit...you're gonna have troubles with a bunch of thoes parts. This has been discussed at length more than a few times on here
14.330 @ 96.37mph
yeah man, your not going to be able to get half of that stuff, you are better off selling what you have and buying the kit
Some of that wiring stuff wont be necessary. Your factory map sensor will fit in the plug on your supercharger so you wont even need those map connectors or anything like that, you will just have to extend the wires to fit. You can find all that other stuff man with just a little bit of common car knowledge. You dont have to get everything from GM.
Douglas Collins wrote:Some of that wiring stuff wont be necessary. Your factory map sensor will fit in the plug on your supercharger so you wont even need those map connectors or anything like that, you will just have to extend the wires to fit. You can find all that other stuff man with just a little bit of common car knowledge. You dont have to get everything from GM.
Are you fully retarded or only partially? You find me a plug on the stock Eco that fits into the TMAP sensor used on the M62 kit and I'll show you some oceanfront property in Tennessee.
14.330 @ 96.37mph
BlownBlackZ wrote:Douglas Collins wrote:Some of that wiring stuff wont be necessary. Your factory map sensor will fit in the plug on your supercharger so you wont even need those map connectors or anything like that, you will just have to extend the wires to fit. You can find all that other stuff man with just a little bit of common car knowledge. You dont have to get everything from GM.
you seem to be a big smartass. on countless occasions. learn some communication skills.
Douglas Collins was referring to how I, Airtonics, and a few others did with our set ups. The cobalt has a sensor on the blower that we don't use and hence that is where we placed our map sensors. That's for a stock map bar.
You are speaking of the T-map, he is speaking about using the stock map sensor....just mis communication.
Chris, your talking about the Tmap connector with the pig tail?? i just bought one from my work..part #88988320...with my discount it was like 65$ or so..lmk if this is what you need and ill order you one..And you can croos the rad hose spport crap of as i didnt use those..the studs and bolts were giving to original purchasee..and the throttle body gasket was on it and sealed
Built&Boosted moar
i believe, just a guess
the first pic is what holds the manifold to the head
the last pic has to do wit the bracket for the alternator and idles...hence the longer bolts
last pic top right......bolts to mount supercharger to manifold?
2 12590822 Int Man Stud----------------- bolt intake manifold to head
5 12590821 Int Man Stud-----------------bolt intake manifold to head
5 11518062 Int Bolt
7 11518532 Int Man / Head Nut--------bolt intake manifold to head
1 12594613 Rad Hse Suprt Brkt---not needed, i dont have one
1 12581198 PCV Connector---this is that connects you pvc port on bottom of supercharger to the lil thing on the powersteering.
1 12052634 Lock Connector--not needed.....keeps connector from comming un plugged
1 12593905 Throttle Bdy Gskt----rtv could work
1 10358940 Brk Bstr Hose........lengthen the factory one
Yeah I was talking about taking your factory map sensor and putting into the s/c instead of using the TMap. I was a little skeptical at first until K Vega, and Airtonics showed me pics and it is true, it does fit right into the s/c. K Vega saved me around 120 bucks just in wiring because that connector just for the Tmap is like 80 bucks not to mention the cost of all the other parts.
Also, if you used the Tmap sensor anyways, you would have issues doing your tune due to the 2.5 bar Tmap and its Resolution. If you use your factory map sensor like we recommend, you dont have to worry about that because your map sensor will never see positive pressure because it is on the inlet side. Shifted, knows a little bit more about the tuning aspect and he will also tell you to leave your factory map sensor and iat sensor in there for tuning purposes.
update
5 11518062 Int Bolt.....
i have this extra
1 11516757 Rad Hse Spt Bolt.....
i have this extra
1 11518048 Drive Blt Bolt....
i have this extra
2 11507067 Rad Hose Nut.....
i have this extra
i have these parts in bold(in proper quantities) if you want em just pay shipping.
they are still in the bags that came w/ the kit
Snowman wrote:update
5 11518062 Int Bolt.....i have this extra
1 11516757 Rad Hse Spt Bolt.....i have this extra
1 11518048 Drive Blt Bolt....i have this extra
2 11507067 Rad Hose Nut.....i have this extra
payment sent. thanks.
Matt Gorman(ECOjunkk) wrote:Chris, your talking about the Tmap connector with the pig tail?? i just bought one from my work..part #88988320...with my discount it was like 65$ or so..lmk if this is what you need and ill order you one..And you can cross the rad hose support crap of as i didnt use those..the studs and bolts were giving to original purchasee..and the throttle body gasket was on it and sealed
i've got the tmap just no connector or pig tails. stefan said he has it tho.
did anyone happen to take pics of their supercharger packets before installing? if so can you post them or email them. my buddy jason and i think we may have numerous bolts that may work just not sure yet. thanks for you help.
snowman-got the package last week. thanks a ton.
to help.....a lil
call your local snapon/matco/ect dealer and ask for a
tap and die for m8 bolts, he should be able to reference it rather easy....maybe 30ish bucks
than buy the standard lsj manifold bolts
swapped, supercharged, intercooled, 2.9, fun
or do what i did and find some bolts that work from the local home depot. lol
Snowman wrote:to help.....a lil
sweet. i think my dad has a tap and die. maybe not. oh so close!
s1lver_N1p wrote:
i do have a number of bolts that i'm tryin to figure out what i have.
any confirmations on these? please be specific on which bolts you are referrin to as well. thanks.
my carDomain updated 3/6/07 Boosted by 100K or B-day!
That one greyish/white/silver bolt in the middle by itself (not the small one in the corner with oil on the threads) looks like the throttle body bolt to me.
There are 4 of them, two long and two short...that's one of the long ones.
I don't remember any black bolts!
The rest honestly look to be brand new and I can't place any other those.
I have two pics of the boxes open before I installed everything but theres not much to see....
oh man. so close. have any bigger pics you can email me? i'm def missin that brake booster line and the wires next to it.
the very top black bolts are to join the snout of the supercharger to the other half of the assembly..
I know this because i shipped it in two peices
Built&Boosted moar
Those 5 in the bottom pic, lower right side look to be the manifold bolts that hold the SC down.
There are 4 of them, all hex heads or whatever they are called....but they look different than mine....maybe not?
