does the gm charger come with injectors because i am gathering all my performance parts for my engine build up this winter and i wanna know if it comes with injectors. or if i should fust go with a bigger injector i plan on running a 2.6 pulley with alk injection.  please help me out . i did do searching.
 http://www.cardomain.com/ride/2623318
you guys think that the 310s will be good with doing the port and polish and secret cams and over sized valves .. or think i should go up on them.. ?
mine ran very lean on the 310's , 13 was the lowest my afr ever went
once i put the 36lb s/c eco injectors i was able to drop to 11.5 , and dropped over half a sec in the 1/4
DONT trust the injectors or tune , use a wide band and see how yours reacts and go from there
[quote=97cavie24ls(™)]mine ran very lean on the 310's , 13 was the lowest my afr ever went
who tuned your car and what was the set up on it?
that was with GM's outta the box tune
hpt wasnt out when i put the s/c on my cav , i used the 36lb and a adjustable fuel pressure reg to control the fuel , i had a custom cai with the filter in the front bumper , and block from engine heat , and header back exhaust , with cat
later i used alky inj to control the s/c heat at the track
