pulley boys belt tool???? - Boost Forum
Saturday, September 15, 2007 2:09 PM
okay i just got the belt tool from pulley boys. dose anyone know what it bolts too? i know it gose on the belt tensioner and what dose the other part bolt too?
thanks james
Re: pulley boys belt tool????
Saturday, September 15, 2007 2:12 PM
i have always just used a long 15mm wrench... i wouldnt know other wise though.
Saturday, September 15, 2007 2:25 PM
yeah the 15mm keeps slipping off so i bought the tool.
thanks,james
Saturday, September 15, 2007 5:17 PM
probably wouldve been cheaper to get a better wrench. i can do mine alone with one wrench
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Sunday, September 16, 2007 12:40 AM
im guessing since you have a 04 in your reg , you are referring the the eco s/c
if you are , then their tool is made to work with the LSJ motor , and not your L61
the LSJ has a bracket that the tool hooks to and srews down on the tensioner and pushes it down to loosen up the belt
i never tried that bracket on the L61 kit
Sunday, September 16, 2007 7:25 AM
oops my message is about the LD9, sorry not sure how bad the L61 is.
650 whp / 543 ft-lb
@turboalero
Sunday, September 16, 2007 9:45 AM
never mine it hooks to the motor puller plate i just had mine off so i put it back on and it works fine.
thanks james
