John Lenko wrote:Doh, sorry dude... never installed it so I didn't realize that was going to be an issue.
I'd pound a small part of the tube flat. That's the "Lazy Lenko" way
Josh Csepegi (CUYOTE) wrote:you could use a wrench to hold the injector in.
jack030 wrote:I have the same kit... but never gave the "gap" issue a thought. It doesn't really have any effect on my setup because I screwed it into a 90 degree rubber elbow right off of the throttle body because my short ram drops straight down off of my H.O. mani.That's kind of funny because I ended up doing the same thing this morning (see attached pic). I couldn't install the injector on the edge of the intake pipe (just before it connects into the elbow) as I have a port opening right there, and I didn't want to chance some freak thing where the line started taking in moisture (with the injector here as well, any unburned fluid will pool down and toward the intake pipe in the elbow, and not on top of the throttle plate). Any further down the intake pipe would have been impossible for me to thread the injector from the inside. I actually still tried putting a rubber washer on even with this install (basically did it because I had already drilled out and tapped the stupid washer), but with it on it wouldn't allow enough threads to come through for the holder to grasp on to. But, once it was in there I cranked the crap out of it and there is absolutely no "non-contact" point now. I even threaded the elbow by drilling out the hole, filling the edges, then taking a lighter to the hole. Once it burned the edges they became hardened and I was able the thread the tap through (I vacuumed out the elbow after and cleaned it with some intake cleaner and a rag to get rid of the debris).
toyotaz87 wrote:do people not read previous posts? ^^^)
Dave Dunsmoor wrote:I hit the reply button to your post the instant I finished reading it because it was a pretty easy answer
