Hi there,
I have searched, however I have not been able to compile a list of better injectors that require no modification to the harness and such in the 00+ 2.4L.
Thanks in advance.
Liiiiike, better flowing injectors?
Just cut and crimp the wires. Make sure they match. It's not hard, just time consuming.
Shifted wrote:Injectors do not have polarity, the only thing you need to make sure is that both wires are on the same injector as the old ones.
So they wires can be mixed up, just not run from one injector to another?
......................................like stock LSJ injectors? thay plug in, but the fuel rail has to be lowered.
Chris
'02 Z-24 Supercharged
Admiral Jedi wrote:Shifted wrote:Injectors do not have polarity, the only thing you need to make sure is that both wires are on the same injector as the old ones.
Correct
Taetsch Z24 wrote:......................................like stock LSJ injectors? thay plug in, but the fuel rail has to be lowered.
Chris
not worth the effort.... just put the new clips on.
but it was worth the money.....
thanks curt!
Chris
I appreciate all the replies, but this does not answer my question, so let me rephrase the question.
If I needed new injectors to add into my turbo setup, without cutting wires, crimping new clips, moving the fuel rail or any other modifications, what injectors can I use? Will the injectors that come in the supercharger kit do that?
Thanks again.
if you only want to flow 30#/310CC...... other wise LSJ is the next easyist
Chris
is it the same for the 2200 injectors
Wrench Monkey wrote:Taetsch Z24 wrote:......................................like stock LSJ injectors? thay plug in, but the fuel rail has to be lowered.
Chris
not worth the effort , LOL
thats a stupid ass comment , its far easier to elongate 2 holes , then it is for most people to rewire the injectors
which is obvious from the amount of times it gets asked
a dumb monkey can elongate 2 holes in about 5 minutes and still have time to scratch his nuts and eat some boogers , and fling some poo poo
Edited 1 time(s). Last edited Thursday, June 28, 2007 3:35 PM
