Hi guys, trust I tried searching, but this is driving me bananas.
Short of going to the junkyard, where can I order the injector clips that I can splice into my stock electrical system to connect up some Accel injectors? Are there ones that are more or less just adapters that you don't have to splice?
Thanks!
Bosch style injector plugs. They are on any mid 90s 3.1M, Tuneport, or even Ford used them on pickups and passenger cars.
http://www.injector.com/electricalcomponents.php
Injector Terminal with Wire leads
This injector terminal fits standard rectangular Bosch-style fuel injectors. Allows custom wiring harnesses, injector retrofits, or wiring repair to be made. Wire length is approx. 7 inches.
Sounds about right? They're 6 bucks a piece... I don't really care, I just need them asap and don't have time to go mucking around at the junkyard again.
I bought mine off of ebay. This isn't the same seller, but they are the same clips...
Click
Yep, that's what I used on my green tops....just match up the wires. If it's got a black line on it, match it up with the one on the clip. I actually had two stock inj wire connectors that had no black line so just use common sense when dealing with those, although it was on a 2.4 so ionno if its different
2000 Camaro V6.
Thanks guys!
Gotta love the boost forum, much more helpful than the other ones
I don't see why going to a junkyard is such a problem for these clips. Theres literally millions of the damn little things in any junkyard. A helpful hint, most any domestic Chrysler fuel injected vehicle uses the same clips. I actually found out that the IAT sensor plugin on any Chrysler TBI car is the same also! We used one off of a spare harness from my Horizon to fix a burnt connector on my friend's 86 Accord. So it's not exactly hard to find 'em. The newer style Chrysler connectors are pretty slick, they use a squeeze type connector instead of the more common spring type and look alot better.
Thanks, but I've already ordered them. Believe me I'm no stranger to the junk yard, but school is started again (summer term), and I have no spare time to go out and get them, so I figured it would be easiest to pay 5 bucks more and have them shipped to my door.
