J-body Part numbers...
to add to list....
GM Part # - Description
12530009 - Curtain (Filler Panel)
22657896 - Trunk Liner
21030249 - Trunk Liner Retainers
22646585 - Rear Seat Cushion Graphite
22646591 - Rear Seat Armrest Assembly
12530009 - Rear Seat Filler Plate
22622577 - Driver Side Airbag
22626394 - 99 Right Outer
59977632 - 99 Right Inner
55977631 - 99 Left Inner
22626395 - 99 Left Outer
22628442 - 2000+ Right Outer
22602878 - 2000+ Right Inner
22628443 - 2000+ Left Outer
22602879 - 2000+ Left Inner
22610683 - Left Fender
22610682 - Right Fender
16516916 - Fender Marker
22637275 - Power Folding Mirror Switch
22626407 - Power Folding Mirror Wiring Harness
22635716 - Power Folding Mirror Coupe Right
22635717 - Power Folding Mirror Coupe Left
22635714 - Power Folding Mirror Sedan Right
22635715 - Power Folding Mirror Sedan Left
22635712 - Manual Folding Mirror Sedan Right
22635713 - Manual Folding Mirror Sedan Left
22649424 - 95+ T O Y O T A emblem
22649426 - 95+ "2.4G" emblem
22649427 - 95+ "2.4Z" emblem
22649425 - 95+ "2.4" emblem
22649423 - Oval "T" badge, Chrome
16757204 - 96-97 only Airbag
16825788 - 98-99 only Airbag
16866011 - 2000-2001 Airbag
Rear strut mounts, part # 22178213
99-02 2.4 exhaust manifold gasket, part # 24576088
2.4 Cyl Head, Part # 24577385
2.4 Injectors, Part # 17122264
2.4 Exhaust Manifold Part # 24576614
2.4 AC Eliminator Pulley, Part # 24574519
93-94 Quad 4 exhaust cam, VIN D #24570698
95 2.3L intake cam, VIN D #24574239
2.4 upper motor mount: 22174933
2.4 throttle cable: 22618841
2.3 ho crank pulley: 24573264
2.4 lower radiator hose: 22659987
2.3/2.4 coolant reservior: 22605500
2.3 intake manifold gasket: 22531631
2.3 tb to manifold gasket: 22542375
2.4 auto trans cable: 22621773
HO Head # 22539086
2724908 ACCUMULATOR
1135437 COMPRESS
O17122264 INJECTORR
Z24 Front Bumper 22597556
Z24 Rear Bumper 22597558Z24 Rt Skirt 12463297
Z24 Lt Skirt 12463298
9384790 ABS Computer
18029730 $26,64 Rear Durastop Brake Shoes
18043141 Brake Pressure MDL
12160244 $8,00 Intake Air Temperature Sensor
12378405 AC Delco SJ 15w40 Engine Oil
24100042 $2,10 Engine Oil Pan Drain Plug (Old Version)
24573264 $100,00 GM Power Crankcase Pulley Balancer and Camshaft
balancer
24576787 $7,40 2000 Z24 Engine Serpetine Belt (Main rubber belt)
24577590 $63,00 Stock Air Filter Box
24577608 $6,95 AC Delco Stock Paper Air Filter # A-1172C
25010633 $3,57 AC Delco Duraguard Oil Filter #PF44
25121293 $8,96 AC Delco Gasoline Filter #GF578
26071430 Power Steering Reservoir
AC Delco Platinum Spark Plugs #AC 41-963 @0.0050in / 1.27mm
88891787 $1,52 Engine Oil Pan Drain Plug (New Version)
9442878 $7,22 Fog Lights Bulb #885 50w Straight
9594585 $3,72 Carbor Fiber Wheel Caps w Red Bow Tie - Wheel Hub Cap
Trim
12368192 $160,08 2000+ Z24 Spoiler - Rear Compartment Lid SPL Kit-C
22633723 $10,50 Door post Covers - Applique
22633724 $10,50 Door post Covers - Applique
22648286 $70,30 Right Applique between right triangle glass and rear
glass
Fog Lights Bulb #880 27w Straight
12559930 $30,00 Corvette Leather Shift Knob
16182995 $8,80 2000+ Climate Knob
$50,72 Center Windows Switch, 2 Doors
$52,49 Center Windows Switch, 4 Doors
6270752 $0,71 Front Stabilizer Shaft (Sway Bar) link insulator (O side
rubbers)
11516328 $0,71 Front Stabilizer Shaft (Sway Bar) bolt
22173158 $53,51 Front Strut Mount and Bearing
22566681 $49,05 Front Stabilizer Shaft (22mm Sway Bar) FE2 Susp (Perf &
Hand Susp)
22566683 $52,12 Front Stabilizer Shaft (18mm Sway Bar) FE1 Susp (Soft
Ride Susp)
22587935 $0,56 Front Stabilizer Shaft (Sway Bar) Clamp (Center D
clamps)
22594028 $6,24 Front Stabilizer Shaft (Sway Bar) white insulator for
FE1 susp
22604347 $40,50 Stock Strut Tower Brace w/o Speed Control
22619843 $6,06 Front Stabilizer Shaft (Sway Bar) red insulator (middle
rubber D-bushings) for FE2 susp
22642387 $40,50 Stock Strut Tower Brace w Speed Control
22657717 $7,16 Front Stabilizer Link for FE1 Suspension (Soft Ride
Susp)
22657718 $6,52 Front Stabilizer EndLink w/rubber bushings for FE2
Suspension (Perf & Hand Susp)
22660396 $0,56 Front Sway Bar Middle D-Clamps for D-Bushings
M10 $1,00 M10 10x1.5 In Bolt
22597314 $7,47 Left Rear Shock Spring Seat Bracket 22619872 $7,47 Right
22177920 $12,10 Front Suspension Bumstops
22129486 $17,50 Rear Suspension Bumstops22064776 $80,00 Front OEM Shock Absorber (Oil Non Gas Presurized)
22064573 $66,00 Rear OEM Shock Absorber (Oil Non Gas Presurized)
12345349 $5,65 Manual Transmission Synchromesh Fluid
21018899 $6,50 Manual Transmission Saturn Fluid
16518385 LH Headlight bracket 99
16518386 RH Headlight bracket 99
95-02 trunk lid 22678456
95-99 z24 front license plate filler 22639556
Toyota airbag? 22622577
#25162600 for o2 sensor on exhaust manifold
#12569553 for o2 sensor after the cat
The part numbers I have are TOYOTA:
Rear seat cushion: 22646585
Armrest assembly: 22646591
Curtain (filler panel): 12530009
22601349 (95-99 2.4 inside door panel) -left
22601348 (95-99 2.4 inside door panel) –right
Stock floor mats graphite carpet front (2) 12370606; rear (2) 12344776; neutral carpet front (2) 12370609;
rear (2) 12344782
2.4 water pump~~~ 12482714
2.4S/C~~~12498287
2.4S/C kit injectors~~~17113399
2.4S/C kit spark plugs~~~05613717
2.3L HO intake manifold – 24572301
2.4 Intake Cam - 25534332
2.4 Exhaust Cam - 25534331
2.4 Head - 24574683 or 24575779
2.4 Intake Valve Springs - 2551567
2.4 Exhaust Valve Springs - 2551567
2.4 Intake Manifold - 24575462 or 24577430
2.4 Motorsport Valve Springs - 25551567
HD Front Wheel Bearing - 7470018
HD Rear Wheel Bearing – 22551705
00-02 Drivers headlight 22666740
00-02 Pass headlight 22666741
Since I'm getting so many emails about them... here's the Toyota Cav dash parts:
Dash panel assembly (that's the main dash piece, read: BIG):
96-99 graphite - 22645992
00 graphite - 22602891
96 light gray - 22645993
96-99 neutral - 22645994
00 neutral - 22602892
97-99 medium gray - 22613666
00 medium gray - 22602893
Dash pad (top piece):
96-00 graphite, light & medum gray- 22637752
96-00 neutral - 22637754
Instrument cluster bezel:
96-99: 22637798
00: 22620045
Radio filler plate:
96-99: 22637797
Metal support (bar under dash):
96-99: 22596097
00: 22625942The HVAC knobs are 9352583
The 95-99 fog assembly numbers are L 16517429 ($100 or so) and R 16517430
GM Strut Bar Standard : 22604347
(Fits All 3rd Gen J-Body's ->2001 that have NO Cruise Control Module)
(Fits All 3rd Gen J-Body's ->2001 that have Cruise Control Mounted to the Firewall)
GM Strut Brace w/ Cruise Control Mounting Bracket: 22642387
Fits All 3rd Gen J-Body's ->2001 that have Cruise Control Module Mounted on the Passenger Strut Tower)
2000 + front strut mounts:
Mount: 22200754
Nut: 22196749
Seat & Bearing: 22182103
95-99 front hub with bearings: 7470014
95-99 rear hub with bearings and wheel sensor: 7470597
95-99 cavalier front strut mounts: 22173158
Front Stabilizer Shaft (Sway Bar) link insulator (O side rubbers): 6270752
Front Stabilizer Shaft (Sway Bar) bolt: 11516328
Front Strut Mount and Bearing: 22173158
Front Stabilizer Shaft (22mm Sway Bar) FE2 Susp (Perf & Hand Susp): 22566681
Front Stabilizer Shaft (18mm Sway Bar) FE1 Susp (Soft Ride Susp): 22566683
Front Stabilizer Shaft (Sway Bar) Clamp (Center D clamps): 22587935
Front Stabilizer Shaft (Sway Bar) white insulator for FE1 susp: 22594028
Front Stabilizer Shaft (Sway Bar) red insulator (middle rubber D-bushings) for FE2 susp: 22619843
Front Stabilizer Link for FE1 Suspension (Soft Ride Susp): 22657717
Front Stabilizer EndLink w/rubber bushings for FE2 Suspension (Perf & Hand Susp): 22657718
Front Sway Bar Middle D-Clamps for D-Bushings: 22660396
Left Rear Shock Spring Seat Bracket: 22597314
Right Rear Shock Spring Seat Bracket: 22619872
Front Suspension Bump stops: 22177920
Rear Suspension Bump stops: 22129486
Front OEM Shock Absorber (Oil Non Gas Pressurized): 22064776
Rear OEM Shock Absorber (Oil Non Gas Pressurized): 22064573
Body Parts
Bumper Skirts
EXTENSION FRT BPR FASCIA (PAINT TO MATCH) 02-02: 12335536
EXTENSION RR BPR FASCIA (PAINT TO MATCH) LH 02-02 L: 12335571
EXTENSION RR BPR FASCIA (PAINT TO MATCH) RH 02-02 R: 12335572
95-99 Z24
Z24 Front Bumper: 22597556
Z24 Rear Bumper: 22597558
Z24 Right Skirt: 12463297
Z24 Left Skirt: 12463298
LH Headlight bracket: 16518385
RH Headlight bracket: 16518386
Fog Lights Bulb #885 50w Straight: 9442878
Carbon Fiber Wheel Caps w Red Bow Tie - Wheel Hub Cap Trim: 9594585
2000+ Z24 Spoiler - Rear Compartment Lid SPL Kit-C: 12368192
2000+ Head Light Brackets for conversion
Bracket 2000-2002 left: 22626691
Bracket 2000-2002 right: 22626692
2003 trunk lid: 22682933
95-02 trunk lid: 22678456
95-99 z24 front license plate filler: 22639556
2003 Z24 Rear Fascia: 12335630
2003 trunk lid: 226829332003 rear fascia (paint to match): 12335630
Harness assembly , its for the rear spoiler on those cars not equipped with a rear spoiler , it plugs into the
main harness: 12148769
2003 rear bumper: 12335580
2000 tall rear spoiler
non painted: 12335354
painted silver: 12496014
LED 3rd light: 22611505
2000-02 spoiler in different colors:
White (paint code 16U): 12496009
Dahlia blue (22U): 12496010
Black (41U): 12496011
Bright red (81U): 12496012
Cayenne red (96U): 12496013
Green met (35U): 12496015
Gold (60U): 12496016
Fern green (36U): 12496017
95-99 Z and 2000+ non-Z spoiler: 12370110
Vent visors
2 door: 12371388
4 door: 12371389
GM side skirts (2 door only): 12495297
GM front end cover (with hood piece) 2000-02 only: 12496934
hood only: 12496935
Lexan hood protector: 10253606
2000 style Wheels
Single wheel: 9593204
Accessory kit: (with centre cap and wheel nuts): 12497054
2002 style Wheels
Aluminum: 9594582
Chrome: 9595065
2002 fascia clips retainer (metal clip): 22688427
2002 spacer (black L-shaped piece of plastic that secures the retainer): 22688428
Natural gas filler door: 52369348
00-02 Drivers headlight: 22666740
00-02 Pass headlight: 2266674
95-99Fog Assembly
Left: 16517429
Right: 16517430
Interior Parts
Door post Covers - Appliqué: 22633723
Door post Covers - Appliqué: 22633724
Right Appliqué between right triangle glass and rear glass: 22648286
Corvette Leather Shift Knob: 12559930
2000+ Climate Knob: 16182995
Rear view mirror w/out map lights: 10221757
95-99 2.4 inside door panel -left: 22601349
95-99 2.4 inside door panel -right: 22601348
Plastic seatbelt bracket cover (graphite): 22584124
Stock floor mats graphite carpet::
Front (2): 12370606
Rear (2): 12344776
Neutral carpet front (2): 12370609
Neutral carpet rear (2): 12344782
2000 dash piece (around cluster and radio, HVAC, etc): 22698064
'00 cavalier air bags
river's Side: 16824968
Passenger's Side: 22663648
Floor mats Set of 4 (netural): 88987277
Engine Parts
2.2
97 2.2 throttle cable: 22659189
Block heater for LN2 engine: 12343314
Oil pressure sender for a GAUGE on the 2.2: 12555492
95-2002 Flywheel for 2.2L engine w/5spd transmission: 10118669
98 2200 oil pan: 88890999
98 2200 crankshaft: 24575689
98 2200 camshaft 2.2L: 12565413
96 2.2 LIFTER X8: 17120070
2.4
99-02 2.4 exhaust manifold gasket: 24576088
2.4 Cylinder Head: 24577385
2.4 Injectors: 17122264
2.4 Exhaust Manifold: 24576614
2.4 AC Eliminator Pulley: 24574519
2.4L lower engine mount
Auto: 22174912
Manuel: 22145447
Fuel pump/sender assembly for 2.4(2000): 22674713
A/C 2.4
ACCUMULATOR: 2724908
COMPRESSOR: 1135437
2000 Z24 Engine Serpetine Belt (Main rubber belt): 24576787
2.4 water pump: 12482714
2.4 Super Charger Kit: 12498287
2.4 Super Charger kit injectors: 17113399
2.4 Super Charger kit spark plugs: 05613717
2.4 exhaust manifold gasket: 24576382
2.3
2.3 HO Head # 22539086
2.3L HO pulley (for 2.4L engine): 24573264
2.3L HO intake manifold: 24572301
Other Misc.
ABS Computer: 9384790
Rear Durastop Brake Shoes: 18029730
Brake Pressure MDL: 18043141
Intake Air Temperature Sensor: 12160244
AC Delco SJ 15w40 Engine Oil: 12378405
GM Power Crankcase Pulley Balancer and Camshaft balancer: 24573264
Stock Air Filter Box: 24577590
AC Delco Stock Paper Air Filter # A-1172C: 24577608AC Delco Duraguard Oil Filter #PF44: 25010633
AC Delco Gasoline Filter #GF578: 25121293
Power Steering Reservoir: 26071430
Engine Oil Pan Drain Plug (New Version): 88891787
Engine Oil Pan Drain Plug (Old Version): 24100042
Manual Transmission Synchromesh Fluid: 12345349
Manual Transmission Saturn Fluid: 21018899
Rear left e-brake cable: 22651234
E-brake cable: 22603399
O2 sensor on exhaust manifold: 25162600
O2 sensor after the cat: 12569553
Isuzu 5 speed slave cylinder: 22638960
EXHAUST PIPE HANGER (1ST DESIGN) BRACKET IS BARE METAL: 22577467
EXHAUST PIPE HANGER (2ND DESIGN) BRACKET IS PAINTED BLACK: 22649018
GM factory lower suspension brace(v6 or quad4 only): 22555480
Transmissions
95-99 2.2L Manual transaxle: 97131256
95-99 2.4L Manual transaxle: 97131255
95-99 2.2L Auto Transaxle: 24215873
95-99 2.4L Auto Transaxle: 24215872
2000+ 2.2L Manual transaxle M94: 22602658
2000+ 2.4L Manual transaxle M86: 22602659
2002+ ECOTec Manual transaxle: 90537868
2002+ ECOTec Auto Transaxle: 90537869
2.4 pistons = 24577471
2.4 rings = 24575965
2.4 head bolts = 24577246
REAR DECK LID
graphite 22616694
neutral 22616695
pewter 22616696
22663028 - gear indicator on '00-'02 auto center console
17113712 - egr valve for 2.4
21006754 - egr valve gasket
22619954 - combination switch (arm on left side of steering wheel)
22652692 - power window switch (for 2 door)
12497971 - driver side window motor
22603640 - '00-'02 center console window switch bezel (graphite)
22633723 - driver side door applique
20038997 - trunk lid arm clip (hold wire loom onto arm)
12346290 - dexcool
22587440 - glove compartment door (graphite)
Extension Front 2002 12335536
Extension rear left 2002 H12335571
Extension rear right 2002 H12335572
12530009 - Rear Seat Filler Plate22622577 - Driver Side Airbag
16757202 - Leather Wrapped Steering Wheel
26051796 - Power Steering Cap
12045049 - Connector for mirrors
22642895 - Radiator Cover Label (in japanese)
22645334 - Radiator Cover Label (in japanese)
22643945 - Radiator Cover Label (in japanese)
22643983 - Radiator Cover Label (in japanese)
24575746 - Radiator Cover Label (in japanese)
22643985 - Radiator Cover Label (in japanese)
22641700 - Radiator Cover Label (in japanese)
GM 2.4 Oil pan gasket = 24574406
SCE 2.4 Copper Head Gasket = 92305
GM 2.4 Timing chain gasket kit = 12360464
GM 2.4 Standered Bore Pistons (99+) = 24504503
GM 2.4 Standered Bore Ring kit (1 cylinder) = 24577471
GM 2.4 Head Gasket = 12462262
GM 2.4 Head Gasket kit = 12482033
2.4L oil dipstick tube (tube only) 24574160
seal for dipstick tube 25534689
retainer for radiator cover – 010134407
22620531 LH front side door outside handle (unpainted)
22620530 RH front side door outside handle (unpainted)
2.4L LD9 Supercharger
Part No. 12498660
2.4L Supercharger
Part No. 12498287
