I just purchased the Accel AFPR from Summit and it did not come with the gasket. Does anyone know where I can get the gasket from? Before I start ripping out the stock one I want to make sure I have all the parts. For these AFPR's are you required to reuse the gasket of your stock fpr. Im sort of lost.
Any help is appreciated, this is for the LD9
Part Number 74565
ps. any tips on installing it, especially when it comes to adjusting?
its just an o-ring that you can reuse. just make sure you put some lube on it before you slide it in. lol
Yeah, no gasket.. just that o-ring
Thanks guys, im gonna do it tonight.
That o-ring can be a major bitch. The last time I took everything apart, the o-ring had gotten moderately stretched out and it didn't want to seal so I had a little issue with spraying fuel all over. Then I just went to the store and got some new o-rings, replaced, and worked perfect.
PUSHROD SQUAD
2200 OHV. 462 hp / 396 tq *RIP*
Abe Froman Video Productions on Myspace (click here)
