I bought a used Turbonetics T04B Super S trim turbo which is supposivly has been upgraded to ceramic ball bearing..Is there any way to tell without taking it apart and having to have it rebalanced? I know if you spin the shaft on a BB turbo it will spin longer than a traditional, on mine it hasnt been used for quite a while so it doenst spin like a ball bearing turbo as it probably hasnt seen oil in a long time..
Anything I can do to be sure without taking it apart?
you can hear the bearings as well when you spin it.
I had a very experienced guy try that and he couldnt hear anything but he still wasnt going to say it isnt a Ball Bearing.
most ball bearing turbos are water and oil cooled, maybe that helps
looking up a S/N does too
No unless you take it apart there is no way to be sure unless there is a sn on the center bearing housing which there probably isnt. Unless someone has a receipt for the upgraded housing i would just assume it does not.
*2012 mazdaspeed3*
paco loco wrote:you can hear the bearings as well when you spin it.
I have a big dual ball bearing turbo sitting next to me right now, you can't hear any bearings when you spin it.
- 93 mph in the 1/8 mile
Member of J-Body Of Michigan.
Yeah, if you hear the bearings from your turbo you got problems. Take it apart and look theres not that much too it. If I bought a used turbo i would want to check out the bearings and fins anyway .
- 97 Z24 Racecar work in progress
- 04 WRX STi
ATR Crew Member
