I have searched but came up with so many different things... Can someone just quickly answer this for me?
Ok, i just recently got a reflashed ecu for the eco charger. But im gonna use it with my Turbo set up. The Question is what else do i need to use this, w/ Turbo? I know i need the new map sensor and connecter i belive...
If anyone could tell me what i need and part numbers that would be great.
I know
TMAP part # 9359409
Connecter part # ???
Everything else part # ????
Thank you
2004 Turbo cavalier 11PSI and blown!
you need the 2.5 map sensor the 330# injectors or saab green top injectors a boost guage a/f wideband guage and i believe thats it you can get the 2.5 map sensor and 330# injectors from www.gmpartsdirect.com and there's also a sticky at the top of the page which would give you more information
You take a women and X her by PSI devide the legs and you can then juice the car......LOL
but the only bad thing about the reflash is the fact it can't be tuned by ANYTHING and the basic gm reflash tops out at 14.7psi
i was thinking about doing the reflash myself to begin with and then getting a 2002 ecotec ecu and using hpt but think i just might go straight for a hpt tune
I had a thread by Snowman bookmarked, but for whatever reason it's not working now.
See if you can find him.
Make sure the ecu is for the right kind of transmission.
I am selling Saab Green tops btw... but they are made for an 02 rail
LE61T PTE6262 Powered
Admiral Jedi wrote:I had a thread by Snowman bookmarked, but for whatever reason it's not working now.
pretty sure it is for the right engine and transmission with the Eco SC reflash..
Thanks again paul...
Is it necessary to use the S/C injectors... As of right now i have eccels.
I got the part numbers from the post from snowman... Im just double checking because in that post it said something about needing the IAT also.
Im just trying to clerify. And Gmparts direct doesn't have the connector(s).
When you wire everything together the IATs will pull from the TMAP sensor. look in the GM sport Compact build guide it tells you the wiring there. Still looking for the numbers to give you as well.
map connector replacement: 12110293
iat connector replacement: 12052641
wire assembly - map sensor: 12590818
I went digging through my instructions; is that what you need?
Can anyone whos running the Reflash With a turbo verify this is what i need, along with the TMAP?
i'm not running the reflash but your doing basically what i'm ganna do and that should be all you need
sorry mike, been busy.
i think that is it... i just hard wired in the tmap...the only thing you would really need to find is the 4 wire connector for the tmap.
from the stock map and iat there are 5 wires....2 of them are gorunds, connect the grounds together and wire in the other 3 along with the grounds to the 4 wire connector, i think it is the "wire assembly - map sensor: 12590818"
cadwz24 how much whp do you think you would run if you upped your boost tp 12psi????\
i'm thinking about doing your exact setup
oh man idk how i missed this thread. here ya go buddy.
again sorry about not being able to switch. it sucks but i would have loved to.
iv been workin on my 240 more. the cav is more or less done. just waiting for the track to open.
anyhoo heres the info
TMAP Sensor- 90423637 $65.06 dealer. the map sensor is larger then the stock one and wont fit in the hole. drill it out to 31/64 for a nice snug fit. need to use some kinda bracket to hold it down too.
Map Sensor Connector w/wiring-88988329
$102.30 dealer
Injector Assembly 12593904 $77.55 ea dealer. gonna need 4. its a 370cc injector and its what the new reflash will be calibrated to read.
ecu reflash 5 speed- 12590820. Archive File .. 1003 reflash is an hours wage at the dealer
thats it man. anything else?
http://www.myspace.com/15102113
John H [Cavalierkid]
$102.30 dealer
Thanks man... Thats exactly what i was looking for!!
i thought all you had to do was plug the new sensors in?? you have to hard wire them?????
can someone elaborate on this
stock map is a 3 prong. new gm map is a 4 prong. u have to wire in with the iat
thanks for letting me know
Anyone have these parts laying around they want to sell or get rid of?
Im just trying to save a lil money!
^^^ LOL... Why you selling your car? How much you looking to get for it?
Ok, im about to order all the parts i need. I just want to double check that what john H said was all that i needed to run the reflash on the turbo eco...
Brining this back from the dead...
But does anyone have the Part numbers for the saab fuel injectors or can anyone tell me what other injectors i can use with thsi GM Reflash w/ 02 fuel rail... I really want to get these things in my hand so i can get my car running agin!!
is this the actual part # for a gm dealer to use for a reflash ?
will this work on a '05 eco w/ a 5spd ?
