Hey guys I need some help. I have a Hahn stage 2 that uses the Accel 32# injectors. I am in need of the fuel injector "pins" that are used to replace the stock fuel injector connectors on the harness. Brad at Hahn told me they could only get them as the entire kit, which I don't need. I only need the pin (maybe a couple to be safe). Does anyone know where to find these? Brad suggested it may be some GM part, but I have no clue where else to look. I searched Accel's website and did tons of google searches. Local shops couldn't help. I really need to get some of these pretty quickly. Any info or suggestions would be great.
"If you aren't shifting, then you certainly aren't driving!"
if you mean the clips check out carcustoms.net
A friend bought injector clips off ebay for like 8 dollars and I was very weary because of the totally crappy quality.
check uner the 2000 2.4 and you will find em... they are like 40 bucks I think
LE61T PTE6262 Powered
Those look kinda right, but I'm not sure if they are. It looks like what I assembled myself. I need the metal pins that are in the black weather seal (the housing). They are just small, long, metal pins that have a sort of crimping end on one side and the other is the part that slides over the pins that stick out of the fuel injector. Also, I'm not sure if these are the same for the injectors I'm using with the Hahn kit.
Does anyone know if those are right or any other info?
