Hey guys,
well, the s/c cavy is having a major hesitation when on the throttle say 2/3-3/4 and it starts off at about 4-5psi and then drops to 0 vacuum (accelarating with the pedal still at 2/3-3/4). When it his 0 vacuum, the car hesitates really badly. Almost feels like a govenor..revs won't climb anymore. When i go wot its not as noticeable, but i think its still there. I've tried running a bit rich, and lean,.. no difference. Looking at the log doesn really tell me to much either
Anybody have a similiar problem? Just pulled the plugs. They look pretty much normal. GOing to try to throw a new set in, but don't think its going to make a difference.
Thanks
Nate
1995 Cavalier W/2k1 Engine
go over all the vacuum lines on it there has to be a vac leak somewhere.
2009 Ford Mustang V6
check where you have your boost gauge t'd into.
no vac leaks. At idle, i'm at about 21-22 in vac. 23 when cruising. I checked over the lines... nothing leaking
Nate
I have the same problem, and have yet to find a solution.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
