where did you run your oil lines from and to?
what engine? what oil line? return? feed?
it's a 2.4 and I need to and from the turbo
I used a 3/16" brake line T'ed from the oil pressure swith to the turbo with no restrictor....
I did have a restrictor but was showing like 0-5 psi when hot...i didnt like it too much, so i took it out and now i see 10 psi when hot. I feel much better with those numbers
As far as retutn goes, i have a 5/8" Braided line from the return side of the turbo to and aluminum bung welded in to the pan....ill post some pics tomarrow when i get a chance....prolly not till later tomarrow night
