I can get a set of stock SRT-4 injectors for free. They are 527 cc. The only problem is they are a bit too short to fit under my fuel rail. Where can I get Spacers for these to make them fit?
youll have to have them custom made
^^^^ he da man , he had 1's made for me
in fact we still need to talk , lol
You can use the spacers from 04 Cavy the little plastic thingys that fit in the head, or LSJ (Cobalt or Saturn).
It's no secret, it fits perfect, I had them on the motor.
11 second daily driver!!!!
Race Related 727-561-9440
13's
----12's
----11's
----10's
that is to fit them into the twin oer the eco? I need injectors....
the eco spacers wont fit the 2.4 head
ive tried
which is why i had them made
but im using the eco LSJ/turbo saab injectors , the green tops , and they are shorter than the 2.4 , but longer than the srt4
WTF happenned to the other posts in here. oh well. How much HP will the green tops support? I cant wait until the HPTuners comes in. I need to figure out this injector thing before that comes in. And do you think I should get an adjustable FPR also?
SunCavi_L61T3/T04E wrote:You can use the spacers from 04 Cavy the little plastic thingys that fit in the head, or LSJ (Cobalt or Saturn).
if they're grey with a black oring around them they're car engine specific and they're used to prevent the injectors from leaking where they go into the cylinder head.
DCStang67 wrote:WTF happenned to the other posts in here. oh well. How much HP will the green tops support? I cant wait until the HPTuners comes in. I need to figure out this injector thing before that comes in. And do you think I should get an adjustable FPR also?
maxed the saabs our at about 11-12 psi (around 240 or so hp). dont know about the srt-4 injectors i haven't maxed them out yet but i did put down around 315 with them and room to spare. yes i'd get an afpr.
Will these injectors fit?
ACCELL INJECTORS
I am a little unsure how to measure my stock ones and compare them to these. If anyone knows how to do this could you please explain?
Yes DC I'm using Accel injectors right now,and I love them but the only problem is that there Bosch style and our injectors on the 2000+ are Delphi style so you'll either have to mod the injector harness by swapping the clips from a 96-99 j-body or by the RC Eng. clips from Car Custom's to use the Accel injector's.
[URL=http://www.carcustoms.net/product_info.php?cPath=266_23_135_607&products_id=405]
Friends Don't Let Friends Drive Stock!!!!!
when you all say clips, are you referring to the metal piece or the terminal connector that makes the electrical connection? the metal piece isnt too important seeing how the rail is already screwed into the cylinder head.
btw i did get your pm dc and i'll get those pictures to you...
so WTF??? what length do we need, and what is needed to put the SRT injectors into a 2000 LD9???
yeah.. umm do any of you have a list or a type specific sizing chart or something that we can tell what will fit w/o modification?
i would rather pay $20 per injector than to have it leak.
