Well,
company seems to be very good and their tech forum and staff are very quick to respond and very helpful.
Product, is very good. Easy install, and seems to work very well. Would reccommend it. The best part is that it has 2 extra wires for stand alone, and i ended up using one for my led light display. So now its even easier to keep an eye on things. It can be plug and played, or as i did, weld in a new bong.
http://www.plxdevices.com/products_M-Series-Controllers.htm
Nate
1995 Cavalier W/2k1 Engine
yeah they make great stuff. I have the 250 with the guage. its to bad I havent hooked up the sensor yet.......I cant seem to break out of a 10:1 flat
Kick azz is my boost hero!!!
u mean bung not bong.
ya, them are nice guages.
i'm new to the wideband thing.......so the regular 250 has a small device that gives a digital readout and the 250 w/guage swaps the little black readout box for a guage?? or does it have both?? any advantage to the guage over the little black box?? do you need to weld in another bung? i noticed it said it had stock narrow band replacement.
k. 300 has the readout on the box, regular 250 doesnt (think its more to hook up to a stand alone setup). but you can get 250 with a circle gauge.
You can put it in to replace ur narrowband, but you have ti find the wires by ur pcm to put in the noise reducers that come with it. It is suppose to be more accurate on its own with a new 'bung'.
Nate
thanks Nate. where abouts did you weld the new bung in on your header??
as far down as possible. RIght close to the the flange for the rest of the exhaust, and after the collector. Not much space down there by firewall. But its seeing all four, rather then one exhaust port.
Nate
thanks. should i got this route i'll get Adam to bung it up!!
