I'm running a Saab 9-3 Turbo/Manifold combo and was just wondering if these injectors would A fit my 03 ecotec and B be sufficent for my application. Just to let you guys know it's the Garret turbo NOT the Mitsu.
Here is the link
Any insight is greatly appricieated!
those are the low boost turbo injectors , i think they are under 30lbs
if your gonna keep the boost in the 4-6 range they MIGHT be ok , depending how you adjust for fuel under boost
if your gonna run higher boost levels , then getting the green tops is better , they are 36lb
and youll reuse your fuel rail , youll only use the injectors
But if I do use them, would they be a direct swap?
yes , thats why i said all youll use is the injectors
Thanks for the info Eric.
If I wanted to get the Saab green tops anyone know where I can find 'em?
do a mamber search for paco loco , he lives in VA or WV , has a black 03 cav and a gto
i got my green tops from him
what I am wondering is does saab have any upgrade injectors? I have the green tops and was looking around for a direct fit upgrade injector for a saab
LE61T PTE6262 Powered
check out abbot racing.they have upgraded turbos
no luck but thanks snowman!
