Well im due to be changing my engine soon and got a few questions about it.  Ive done many engine replacements but never in a j.
-Is it possible to get the old engine out and the new one in without removing the trans?
-The engine I have hasnt been run for quite some time...is it advisable to disable the fuel pump and turn it over a bit to prime the oil and such?
-The car currently has dex-cool in it....New motor is empty...Should I run dex-cool or regular..ive heard so many conflicting stories..
-Changing over to synthetic...any special things to do?
-Plan on keeping the stock clutch but is there a way to see if its still got life in it?
Thats all for now....but im sure ill have some more questions..thanks alot..Phil
Great..thanks..
For changing from dex to normal...do I just dump out what I can or do I have to have it 100% clean...ie rinsed with water and such?  And I remember with dexcool and my aluminum block in my bike I had to use distilled water...same with regular?
I guess since im pulling the tranny...what kind of tranny fluid do the 5spd ecos work best with?
New car has a/c and ive never worked with a/c....where do I disconnect it so I dont have to recharge it?
Will I have to bleed the clutch? If so is there a trick on these cars?
By universal gold you mean like prestone all makes/types?  Whats the capacity of our coolant system?
It's REALLY easy to recharge your AC so don't be too concerned about that. You can get a lil kit at the auto part store that has all you need w/step by step instructions and I think it's only like 20$ or so.
My grandpa does a/c so I'm not to concerned.... But if I could keep it that would rock
