Ok. About a month ago I had my flex pipe replaced cause it had split completly in half. So my exhuast sounded great for that month. Now under light accelleration it sounds the opposite of a turbo sucking air in. It's sounds like a backwards turbo.
But I can't seem to find the leak. Does anybody have any ideas? Has anybody ever run into this before?
only thing you can do is have all of your exhaust welded together if you don't know where it's coming from really. and make sure the header is good and tight on the head.
So I was changing the oil and started it up while on stands and found the flex pipe leaking again. Took it and got it fixed for free since it was replaced less than two monthes ago.
