im curious about brake upgrades, what is a good start for a sunfire? how do i go about rear disks, i hate drums. slotted, drilled or both for rotors? do they really help and hold up? if anyone has any info to share plase do. thanx
Fireboy153
Brady Fire Co. - Station 150
Long Live The Sunflower! (yea its not so "cool")
What do you dislike about the brakes you have now?
You have to tell us the problem before we can give you the solution.
big brake kits are expensive but they look so nice
you can go with slotted rotors and Ti22 brake pads for the front. thats what i have
and rear disc conversion
SSBC, Bear, or Wilwood if you want big un's. or you could visit a newer W body in a junkyard and swap a lot of parts.
SSBC is the best as far as I'm concerned as far as big brake kits with the rear disc conversion go but there are a few other good ones too.
Simply changing the front brake pads and using slotted rotors will give you a nice increase in braking performance, and won't "break" the bank. If it's looks you want, you'll have to spend some $$$, cause big brake kits aren't cheap, and you need to run 17's with most of them.
For Sale:
'01 SFGT springs $50CAN
Fidenza Flywheel '00-'02 2.4 (getrag) $300CAN(SOLD)
Custom97sunfire wrote:SSBC is the best as far as I'm concerned as far as big brake kits with the rear disc conversion go but there are a few other good ones too.
What makes them better than Baer, in your opinion? Just curious...
$600 ssbc vs. $800 bear. although i think bear has a two piston caliper in the rear.
No, they both use a single piston caliper in the rear.
I believe the SSBC kit requires 18" wheels for their 13" front kit and you have to machine the knuckle yourself if I'm not mistaken.
I was just curious as to your reasons. I thought maybe it was something other than price.
I'll take my Wilwood rear disc conversion
i love my Baer big fronts and i will love my baer rear discs.when they get here
<img src="http://registry.gmenthusiast.com/images/snowman/thumbnail_sunfire.gif">
<img src="http://registry.gmenthusiast.com/images/snowman/thumbnail_personal_pic.jpg">
