The turbo and NA heads are the same.
He's right, the heads are the same, but the cams ARE NOT.
Keep this in mind.
You can find a head from the junkyard, if they haven't been pulled for scrap ( they are cast aluminum) and put it on with the turbo cam installed.
You can use the NA cam with the turbo car, but it might run weird since the ECU may need tuned.
Good luck though.
Quite the find for $750.
How's the body look?
You have a 240Z? That is 100% cool. I have nothing useful to contribute here.
2010 Honda Fit LX
The turbo heads and all heads 82'-91' have a hart shaped combustion chamber,91'-94' have a "D" shaped raising compression.
I have a spare head and camshaft if anyone needs it.
