On my 94 the dome light does not come on when the door is opened and I have no chimes. What do I need to do to fix this
Sounds like a bad convenience module. Its above the driver's kick panel. The hazard flasher is mounted on the same plastic block. Its a simple pull and replace deal. Finding a good one is tough though. Does your car leak through the firewall? Most of the time, the module goes bad because it gets wet.
i probably have a ton of them, if someone can get me a pic ill pull one out of a car in the yard and send it to ya. i have 20 cav's one has gotta have a good module
