Hello guys,
I need to know if all quad 4 engines came with the 33lb injectors or if it was only the HO engines (175-190hp)?
Also are the 33lb injectors high or low resistance?
I pulled some from a yard from a 92 DOHC quad 4 (not sure if HO or not) and the injectoirs all tested at 16 ohms (high impedance).
Any help is very much apprectaed. Thank you!!
-Brandon
Hello guys,
I need to know what the quad 4 HO engines 33lb injectors look like?
EDIT:
OK I pulled three sets of injectors today. Two sets are black bodies, but are different, and one was from a 92 and one from a 95. the other set was from a 89 I think, and instead of black the injectors were grey in color
Are any of these 33 lbers'? that is what I am looking for, but dont want to install the wrong size injectors as my setup will be turbocharged
