i'm selling a C20GET motor complete.
the motor has been fully machined and is ready to be built.
off the top of my head the parts list includes...
• C20GET block
• Mahle pistons and rings
• C20GET rods and crank (reconditioned)
• C20GET head (Completely rebuilt)
• new GET cam
• performance followers (stronger then factory)
• new lifters
• GET intake manifold with injectors, fuel rail, TB...
• GET turbo manifold
• T25 (might need rebuilding)
• T25 inlet and down pipe
• T25 oil return
• motor mount bracket
• new oil pump
• new water pump
• new timing belt
• complete rebuild gasket set
• new bearings, crank and piston
• accessories brackets
• ALT if needed
• distributer or DIS block off for the distributer, you can use your coil pack
i'm sure there is more but this is all i can think of for now.
i'll include a price list for each of the parts if you where to buy everything separate like i did. with the parts and machining i think i spent around $3000 if not more.
i would like $1500 + shipping (around $450 depending on where you are) but i will entertain offers
garrett
an MLS head gasket would be needed to complete this build.
you can call Cometic direct to order @ 1.800.752.9850.
C4216-051
 VAUXHALL 16 VALVE 2L 88MM
 .051" MLS HEAD GASKET
 $86.50
C4216-060
 .060" MLS HEAD GASKET
 $100.90
C4216-065
 .065" MLS HEAD GASKET
 $100.90
C4216-074
 .074" MLS HEAD GASKET
 $109.15
Brandon Hare
Cometic Gasket
8090 Auburn Road
Concord, OH  44077
Phone:  440-354-0777 Ext. 133
Fax:  440-354-0350
garrett
Helllo
is it still for sale?
if someone has one and wants to export to europe
corsasjop@yahoo.com
thanks
Hi.  It's 2012.  Any motors or parts for this engine or it's setup?
Jeff
I could use any parts you may have
Jeff
