trouble starting when hot?????????? - Second Generation Forum
Monday, May 22, 2006 7:08 PM
well, just wondering if anyone eles has come across this problem. the car starts fine when its cold, as soon as it heats up it won't turn over, changed the starter, thats wasn't it. i'm waiting for new ignition parts. i'm not sure if that's what messed, but it needed to be changed anyway. any input would help, thanks
Re: trouble starting when hot??????????
Monday, May 22, 2006 7:23 PM
Have you checked the Negative Battery cable at the Battery connection and at the chassis earth point(s)?
Almost sounds like a bad connection somewhere in the Negative or Positive feed to the starter.
Worth cleaning the contacting points anyway
Alont
Tuesday, May 23, 2006 11:27 AM
make sure everything on the starter is tight. and like ALONT said, check your terminal wires. for looseness and corrosion.
http://www.personal.psu.edu/users/a/t/atl126/ricers1.gif
Thursday, May 25, 2006 5:19 PM
Check the coil packs my friends rs had that problem it was the coils.
Saturday, May 27, 2006 4:45 AM
You say it wont turn over. What does that mean to you? No crank? Cranks but no start? I've run into this phrase before and it doesnt mean the same thing to every one.
Does it stall at all after running for a while?
01 cav w/01 3400 gam gt 4t45e
Saturday, May 27, 2006 7:01 PM
it cranks but won't start, and hasn't stalled on me when it does run. i have msd coils, plugs and wires ordered, just waiting them to come in. i also have a parts car that i'm the taking ignition module off to see if thats it. just need to find the time. thanks for input guys.
ryan99
Saturday, May 27, 2006 8:05 PM
Unless you just want to change those parts any way, you need to find out what is causing the no start. There is no way that you like to change the ignition module or coils more than once. Been there it sucks. Any way You need to find out if its getting spark, fuel pressure and injector pulse. get these things and It runs. You may change those parts that you said that you ordered and its fine. But since its intermittent wouldnt you like to know for sure that a part is bad before driving it some where.
unlikely that its the batt cables because it cranks.
Intermittent problems are the hardest ones do diagnose, so dont give up.
Sunday, May 28, 2006 12:34 AM
Do you have a header or any excessive overheating?
I have no clue where the starter is in a J-body, but it could be getting heat soaked.. just a possibility.
Sunday, May 28, 2006 1:56 AM
if the engine is turning, replacing the starter would be a little goofy. Is it even trying to start? Does it put? Does ANYTHING happen while it cranks? Can you smell fuel coming from the tail pipe while cranking? Can you hear the fuel pump turn on when the key turns? Does it have full normal power when it reaches temperature? Have you done a compression test while it is hot? Have you put a high energy ignition tester to it while hot?
If you can't answer all of those questions, you shouldn't be buying anything for it yet.
Cardomain|Myspace
Saturday, June 03, 2006 5:22 AM
Ok well if your engine it turning when your trying to start it and it no start. The problem isn't with your starter. My Girl had this problem with her Lumina. Had a 3100 in her. What went on her car what the air idle control valve. Id go out and push the pin in and shed start.
Saturday, June 10, 2006 9:20 PM
Ron Love Online
Check for codes on the ecm.First is the crank shaft position sensor (19) and also code (35) idle air control or iac valve.Being u have upgraded ur coil I would not rule it out but,a the above are probably a most likely unless the check valve for the fuel is gone bad which inturn does not throw a code,its about doing a diagnostic like verifying fuel going to the rail and proper fuel pressure coming from the pump.Check those things provided it is just turning over with no start going on as it is now.That is where I would start to narrow down the issue.
