ight im running the 2.2 engine with a 5 speed tranny with the   apc air intake system. i was running at about 80 psi of oil pressure, then it started dropping, changed the oil, and its still dropping now, usually running at about 20 psi now, anyone had this problem and a fix??? thanks
when cold you'll get 80 psi.  When hot, 20 psi is normal.
All that at Idle.
Gilles
2.3 Ho
