Does anyone on here replace cluster bulbs on the 00+ clusters? I have a couple bulbs out in my sunfire gauge cluster that I would like to get fixed so I can use it again. I would just like to replace all the led bulbs if possible. and also along with that does someone have a 00+ sunfire HVAC panel with air and rear defrost that they're looking to sell?
2009 Ford Mustang V6
When I first installed my sunfire cluster the temp area didnt light up very well. So I hit the dash with my fist and it worked fine ever since.
for your situation, a hammer.
When I hit the dash more cluster bulbs went out lol. So I just want to get them all replaced and go on my way with it. Hopefully someone here can help a fellow org member out.
y not just buy leds for your HVAC? would be cheaper than buying the whole sunfire unit.
my carDomain updated 11/5/07 I've got premium. Yes I do. I've got premium. How 'bout you?
i did this on my 99 blazer. pull out the cluster. then theres the black part on the back. take that off and the bullbs should be right there thats how it was on my blazer. just go along and look for the clips that hold the cluster together.
I believe your LEDs are sodered right to the curcuit bord. So good luck with swaping them out.
if you give me a few hours i might be able to make something work out for ya granted its out of the car already
9-19-05/1-7-07
CarDomain
BUY MY CAR
Tinkles wrote:I believe your LEDs are soldered right to the circuit board. So good luck with swapping them out.
yep. finally found the thread. thought i had it saved
already
Edited 1 time(s). Last edited Monday, January 28, 2008 6:54 PM
i tried, i failed miserably, sometimes its easier just to get a new cluster
