I am selling the parts that i have for the F-W body big brake upgrade. I have the spindles, wheel bearings, calipers (camaro dual piston), axles with axle nuts, and ebay cross drilled slotted rotors. I need to get 300.00 out of this stuff.
Hmm... This swap gives you the 5 x 114 setup in the front right? I can't remember the bolt pattern for the life of me.
It sure does, but disregard the FS part
. I figured out what i can do to make them fit
LoL Hmm lookin' at the pic's can I ask is it move the studs over to the other holes on the hub? Not sure if that is 5 x 100 or still the 5 x 114. Wouldn't it be nice if your rims did both patterns...
Did you forget that or something before you posted these? Guess it wouldn't be all that hard then huh... If you get a chance let me know what parts came from what since I'm wanting to do this sometime this summer with more funds are around.
no im a retard, i knew they would bolt on but i tried plaing my rim on one of the hubs and it would not go all the way on. I did not have a rotor on there to take up that gap
