New items added to list, updated list and prices.
- blue/black ractive racing seats, great shape, will mount to your stock sliders with little modification ..... 150 for the pair
- 00-02 Cav rear silver lip, small hairline crack in one side (does not go all the way through) , nothing major, good shape otherwise.... 60
- fiberglass special, drift front and sides, front was hit, sides were cut to be customized, 40 bucks for it all. (front is for the 95-99 cav but im sure you could make it work with anything)
- 4 point ractive harness, never installed, black... 40
- 00-02 cav headlights and corners, were taken apart and painted black by prev. owner, need a little work, ... 30
- 00-02 black cav trunk lid with spoiler (led tail) GREAT SHAPE only one or two scratches and has red z24 emblem etc in tact... best offer
- rear bench out of a grand am GT, would need to upholster to your interior colour etc, good shape... 30
- sunroof for cav or fire, great shape, everything works, also have a beige headliner... 50 (comes with switch etc)
- m3 tyle mirrors for the 2dr, im sure they would work on the 4 dr? they are carbon fiber style, with led turn signals and power options... 50
-  dual guage pod molded into a pillar, smoothed and painted black- 80
- dual guage pod not molded, uses 4 caps to hold onto a pillar, already mounted and comes paint matched to graphite interior - 50
- ractive Volt meter with tinted faceplate and multi colour leds, used for 4 months - 40
- ractive oil pressure guage with electronic sending unit used 4 months, tinted faceplate with multi colour leds - 40
- front strut bar, has CF design on it but it is peeling and needs to be sanded... 40
- 99 sunfire top dash pad painted black, good shape - 30
- 99 sunfire center console, smoothed and painted - needs to be painted to your interior, - 30
- cav trunk, black, no spoiler, shaved key hole - best offer
- MTX Thunder 7804 Super amplifier 4 channel amp with 4 channel RCA's, used for 2 months, still have original box - 300
                    Thunder 4-channel Super Amplifier featuring patented class A/B output
                    100 watts RMS x 4 at 4 ohms, 200 watts x 4 at 2 ohms
                    400 watts RMS x 2 bridged output at 4 ohms, 800 watts x 1 front/rear summed output
                    Xtant Technology Cooling (XTC) - Thermal-regulated turbo-charged fan intercooler
                    PrizmEFX accent lighting effects - Customizable to match your vehicle's interior
                    Semi-unregulated MOSFET power supply
                    Overload and thermal protection
                    StreetWires connection terminals
                    Variable electronic crossover at 40~350 Hz, selectable 12 dB Hi/24 dB Low Mono, defeatable
                    Bass boost at 40 Hz, 0~18 dB/octave variable
                    A.R.C. (Active Resonance Control): Cut 0~15 dB/octave, Freq. 200 Hz
                    Input (RCA connection): Low-level, hi-level w/Smart Engage
                    Input sensitivity: 100mV-1V/1V-10V switchable
                   CEA-2006 Compliant
                   Dimensions: 20-11/16" L x 9-5/8" W x 2-1/2" H
- MTX 6001 mono amp- 300 bucks
Andrew
