It seems my Front Right Turn Signal is burnt out, and I need the 3457 Blub for it. There's only 1 problem. It seems that Wal-Mart, Canadian Tire, Part Source & GM don't carry those bulbs anymore. They only carry the 3457NA (the Orange Bulbs), and they say that the orangle ones won't work behind an orange lens. They say the Sunfire is one of the only cars left that uses that clear bulb. Does anyone know where in Ottawa I could find the clear 3457s?
Also, doesn anyone know if there is a clear lens that i would be able to get for the 99 Sunfire, since the only 3457s available are the NAs?
Let me know,
X
Just use the 3457NA bulbs...They do work behind the orange lens I know first hand.  I'm using them on my 2000 sunfire, with no problems. Hope this helps
change number and get 3157
 you can get them in clear they will also work
worst case.... go to the dealer, they must have them... wouldnt they?
***Thanks again to stargrrrl***
I'm using 3157's in my turn signals.  What's the difference between the two?  Did they change bulbs in 2000 or did I just put the wrong ones in and not notice?
thre is alittle different in the brightness of the bulbs but not enough to notice............most cars actually have the 3157 not the 3457
